efficient matrix block assignment
Umut Tabak u.tabak at tudelft.nl
Thu Aug 6 08:18:17 CDT 2009
Dear all,
I am trying some block matrix assembly in Petsc, so far, I was puzzling
with the right calling and set up of MatSetValuesBlocked. Matthew
Knepley confirmed my previous post. I guess it is the function I should
use. But it accepts the values as a 1D array, which is  represented in
row major order(by default). So the burden on this approach is to
convert my Matrix into a 1D array, this seemed as the only solution for
the moment. If I would like to use this function.
Another way I could think of by reading the documentation of Matrices,
is to use MatGetColumnVector and assign over column vectors, but the
above approach is far more efficient, I guess.
BTW, some blocks are square and some are rectangular, with block size
type operations, I guess it is not possible to assign rectangular
matrices to some part of a larger square matrix.
Are there any other efficient suggestions?
Best regards,
Umut
