A point on documentation of MatSetValuesBlocked
Umut Tabak u.tabak at tudelft.nl
Thu Aug 6 05:05:16 CDT 2009
Dear all,
There is sth which took some time for me to figure out from the
documentation
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatSetValuesBlocked.html#MatSetValuesBlocked
Or my English is getting worser, In the explanations that are a part of
this function,
The m and n count the NUMBER of blocks in the row direction and column
direction, NOT the total number of rows/columns; for example, if the
block size
<http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Sys/size.html#size>
is 2 and you are passing in values for rows 2,3,4,5 then m would be 2
(not 4). The values in idxm would be 1 2; that is the first index for
each block divided by the block size
<http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Sys/size.html#size>.
But the puzzling point is that there are no pointers for the setting of
the block size and hyperlinks on size also do not direct to the right
locations in my humble opinion.
However, proper block size setting should be done before using this
routine with MatSetBlockSize. Am I right?
And this page has no pointers to that function. After reading the
documetation, I had the idea in the mind that, you decide on the block
size, and do the computations on paper for m,idxm,n and idxn to be
supplied to the routine but ,apparently, without a call to the function
the programs can not know the block size, which is logical.
I felt myself a bit dump, and wanted to notify you about this if someone
else also experiences the same problem in the future, maybe adding a
link there for the above mentioned function is a good idea.
   //MatSetBlockSize(A, 3);
   const int idxmNew1[] = {0};
   const int idxnNew1[] = {0};
   PetscScalar vals1[] = { 1.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 1.0  };
   MatSetValuesBlocked(A, 1, idxmNew1, 1, idxnNew1, vals1, INSERT_VALUES);
   ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
   ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
Running the above piece of code of course sets only M[0][0] with out
proper setting of the blocks. Or do I still have some misunderstanding
on the use of this function?
Best regards,
Umut
