make test errors
    Yixun Liu
    enjoywm at cs.wm.edu
    Wed Aug  5 08:35:35 CDT 2009
I did as what you said,
mpiexec -n 2 ./ex2
DAT: library load failure: /usr/lib64/libdaplcma.so.1: undefined symbol:
dat_registry_add_provider
WARNING: Failed to open "OpenIB-cma"
[DAT_PROVIDER_NOT_FOUND:DAT_NAME_NOT_REGISTERED].
This may be a real error or it may be an invalid entry in the uDAPL
Registry which is contained in the dat.conf file. Contact your local
System Administrator to confirm the availability of the interfaces in
the dat.conf file.
Satish Balay wrote:
> Try running manually - and see if the example works. These messages
> could be verbose - and misleading.
> i.e
> cd src/ksp/ksp/examples/tutorials
> make ex2
> mpiexec -n 2 ./ex2
> Or you can avoid this by installing mpich - instead of openmpi.
> Satish
> On Tue, 4 Aug 2009, Yixun Liu wrote:
>> I'm not familiar with MPI. Are there some easy way to test it?
>> Matthew Knepley wrote:
>>> On Tue, Aug 4, 2009 at 3:51 PM, Yixun Liu <enjoywm at cs.wm.edu
>>> <mailto:enjoywm at cs.wm.edu>> wrote:
>>>     Hi,
>>>     I encounter the error as I run make test,
>>>     >make test
>>>     Running test examples to verify correct installation
>>>     Possible error running C/C++ src/snes/examples/tutorials/ex19 with
>>>     1 MPI
>>>     process
>>>     See
>>>     http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
>>>     symbol:
>>> This looks like a bizarre failure with your OpenMPI compiler wrappers.
>>> Do they work
>>> at all?
>>>   Matt
>>>     I list the output of configure. Hope it helpful for diagnosis.
>>>     > ./config/configure.py --download-parmetis
>>>     TESTING: alternateConfigureLibrary from
>>>     PETSc.packages.petsc4py(config/PETSc/packages/petsc4py.py:69)
>>>     Compilers:
>>>      C Compiler:         mpicc  -Wall -Wwrite-strings
>>>     -Wno-strict-aliasing -g3
>>>      Fortran Compiler:   mpif90  -Wall -Wno-unused-variable -g
>>>     Linkers:
>>>      Static linker:   /usr/bin/ar cr
>>>     PETSc:
>>>      ** Before running "make" your PETSC_ARCH must be specified with:
>>>      **  ** setenv PETSC_ARCH linux-gnu-c-debug (csh/tcsh)
>>>      **  ** PETSC_ARCH=linux-gnu-c-debug; export PETSC_ARCH (sh/bash)
>>>      PETSC_DIR: /home/scratch/yixun/petsc-3.0.0-p3
>>>      ** Now build the libraries with "make all"
>>>      Clanguage: C
>>>      PETSc shared libraries: disabled
>>>      PETSc dynamic libraries: disabled
>>>      Scalar type:real
>>>     MPI:
>>>      Includes: -I/usr/lib64/mpi/gcc/openmpi/include
>>>     -I/usr/lib64/mpi/gcc/openmpi/lib64
>>>     X11:
>>>      Includes: ['']
>>>      Library: ['-lX11']
>>>     BLAS/LAPACK: -llapack -lblas
>>>     ParMetis:
>>>     -I/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/include
>>>      Library:
>>>     -Wl,-rpath,/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib
>>>     -L/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib -lparmetis
>>>     -lmetis
>>>     Yixun
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
