make test errors
Matthew Knepley
knepley at gmail.com
Tue Aug 4 16:21:58 CDT 2009
On Tue, Aug 4, 2009 at 4:03 PM, Yixun Liu <enjoywm at cs.wm.edu> wrote:
> I'm not familiar with MPI. Are there some easy way to test it?
1) You can tryu using MPICH instead, with --download-mpich
2) You can try compiling a simple program on your own and running it
3) I suspect that there may be a problem running on this machine. It might
be that the configuration is different than the "compute nodes" since it
appears that you can't see a library you need.
Matt
> Matthew Knepley wrote:
> > On Tue, Aug 4, 2009 at 3:51 PM, Yixun Liu <enjoywm at cs.wm.edu
> > <mailto:enjoywm at cs.wm.edu>> wrote:
> > Hi,
> > I encounter the error as I run make test,
> > >make test
> > Running test examples to verify correct installation
> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with
> > 1 MPI
> > process
> > See
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> > DAT: library load failure: /usr/lib64/libdaplcma.so.1: undefined
> > symbol:
> > dat_registry_add_provider
> > This looks like a bizarre failure with your OpenMPI compiler wrappers.
> > Do they work
> > at all?
> > Matt
> > I list the output of configure. Hope it helpful for diagnosis.
> > > ./config/configure.py --download-parmetis
> > TESTING: alternateConfigureLibrary from
> > PETSc.packages.petsc4py(config/PETSc/packages/petsc4py.py:69)
> > Compilers:
> > C Compiler: mpicc -Wall -Wwrite-strings
> > -Wno-strict-aliasing -g3
> > Fortran Compiler: mpif90 -Wall -Wno-unused-variable -g
> > Linkers:
> > Static linker: /usr/bin/ar cr
> > PETSc:
> > ** Before running "make" your PETSC_ARCH must be specified with:
> > ** ** setenv PETSC_ARCH linux-gnu-c-debug (csh/tcsh)
> > ** ** PETSC_ARCH=linux-gnu-c-debug; export PETSC_ARCH (sh/bash)
> > PETSC_DIR: /home/scratch/yixun/petsc-3.0.0-p3
> > ** Now build the libraries with "make all"
> > Clanguage: C
> > PETSc shared libraries: disabled
> > PETSc dynamic libraries: disabled
> > Scalar type:real
> > MPI:
> > Includes: -I/usr/lib64/mpi/gcc/openmpi/include
> > -I/usr/lib64/mpi/gcc/openmpi/lib64
> > X11:
> > Includes: ['']
> > Library: ['-lX11']
> > BLAS/LAPACK: -llapack -lblas
> > ParMetis:
> > -I/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/include
> > Library:
> > -Wl,-rpath,/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib
> > -L/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib -lparmetis
> > -lmetis
> > Yixun
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090804/eb066d24/attachment.htm>
