There is no return value for bin/matlab/PetscReadBinaryMatlab.m?
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Aug  3 15:21:00 CDT 2009
   Do you have the latest PETSc 3.0.0 with all its patches?
On Aug 3, 2009, at 3:16 PM, (Rebecca) Xuefei YUAN wrote:
> I used PetscBinaryRead('solution') before, but it kept returning the
> error message:
>>> c = PetscBinaryRead('solution');
> ??? Undefined function or method 'freader' for input arguments of
> type 'char'.
> Error in ==> PetscBinaryRead at 22
>  fd = freader(inarg);
> The Petsc function I use to save this binary file is
> PetscViewerBinaryOpen().
> Since that is not successful, I started on my own...
> Cheers,
> R
> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>>   Use bin/matlab/PetscBinaryRead.m with
>>   The help for PetscBinaryRead.m indicates other uses also, for
>> example, if you put multiple PETSc objects into the same viewer.
>>   Barry
>> On Aug 3, 2009, at 2:51 PM, (Rebecca) Xuefei YUAN wrote:
>>> Dear Barry,
>>> I might not state the problem clearly, I saved my solution to a
>>> binary file named "solution", so after running the code, there
>>> two  files "solution" and "solution.info" were formed. Then I
>>> would like  to the following matlab function to load the data:
>>> fid = fopen('solution','r');
>>> c = fread(fid);
>>> What I would like to have for c is a 1d Array with 36
>>> elements(real  number), however, it turns out that c is a 1d array
>>> has 1116  elements(integer), what is wrong with it? Do I miss
>>> anything? Or  the binary file from Petsc is different from the
>>> normal binary file?
>>> Thanks very much!
>>> R
>>>> I use PetscBinaryRead.m then call the plot routines directly in
>>>> Matlab.
>>>> You can also use the PetscReadBinaryMatlab() stuff to put the
>>>> contour
>>>> commands directly in the .info file and then use
>>>> Barry
>>>> You can use PetscReadBinary
>>>> On Aug 3, 2009, at 1:32 PM, (Rebecca) Xuefei YUAN wrote:
>>>>> Dear Barry,
>>>>> Thanks very much! If this is the case, do you have any
>>>>> suggestions  to load the binary file into matlab thus doing the
>>>>> output, like  contour(u)?
>>>>> Thanks!
>>>>> R
>>>>>> Thanks for reporting this. The documentation for this Matlab
>>>>>> function is wrong, it doesn't actually return anything.
>>>>>> I have fixed the docs and it will be fixed in the next patch.
>>>>>> Barry
>>>>>> On Aug 3, 2009, at 8:04 AM, (Rebecca) Xuefei YUAN wrote:
>>>>>>> Thanks,
>>>>>>> Department of Applied Physics and Applied Mathematics
>>>>>>> Columbia University
>>>>>>> Tel:917-399-8032
>>>>>>> www.columbia.edu/~xy2102
>>>>> Columbia University
>>>>> Tel:917-399-8032
>>> Columbia University
>>> Tel:917-399-8032
> Columbia University
> Tel:917-399-8032
