There is no return value for bin/matlab/PetscReadBinaryMatlab.m?
(Rebecca) Xuefei YUAN xy2102 at columbia.edu
Mon Aug 3 14:51:41 CDT 2009
Dear Barry,
I might not state the problem clearly, I saved my solution to a binary
file named "solution", so after running the code, there two files
"solution" and "solution.info" were formed. Then I would like to the
following matlab function to load the data:
fid = fopen('solution','r');
c = fread(fid);
What I would like to have for c is a 1d Array with 36 elements(real
number), however, it turns out that c is a 1d array has 1116
elements(integer), what is wrong with it? Do I miss anything? Or the
binary file from Petsc is different from the normal binary file?
Thanks very much!
R
Quoting Barry Smith <bsmith at mcs.anl.gov>:
>   I use PetscBinaryRead.m then call the plot routines directly in Matlab.
>   You can also use the PetscReadBinaryMatlab() stuff to put the contour
> commands directly in the .info file and then use PetscReadBinaryMatlab.m
>    Barry
>    You can use PetscReadBinary
> On Aug 3, 2009, at 1:32 PM, (Rebecca) Xuefei YUAN wrote:
>> Dear Barry,
>> Thanks very much! If this is the case, do you have any suggestions
>> to load the binary file into matlab thus doing the output, like
>> contour(u)?
>> Thanks!
>> R
>>>  Thanks for reporting this. The documentation for this Matlab
>>> function is wrong, it doesn't actually return anything.
>>>  I have fixed the docs and it will be fixed in the next patch.
>>>  Barry
>>> On Aug 3, 2009, at 8:04 AM, (Rebecca) Xuefei YUAN wrote:
>>>> Thanks,
>>>> Department of Applied Physics and Applied Mathematics
>>>> Columbia University
>>>> Tel:917-399-8032
>>>> www.columbia.edu/~xy2102
>> Columbia University
>> Tel:917-399-8032
Columbia University
Tel:917-399-8032
