tolerance for diagonal entries + Slepc
    Hong Zhang
    hzhang at mcs.anl.gov
    Mon Aug  3 09:13:31 CDT 2009
Umut,
The error msg
"Matrix is missing diagonal entry 1847!"
has nothing to do with the tolerance.
It indicates that you did not input any value
to the 1847-th diagonal entry.
Many routines required diagonal entries been
allocated and set.
If that entry is zero, you should set zero value to it.
Hong
On Mon, 3 Aug 2009, Umut Tabak wrote:
> Umut Tabak wrote:
>> Dear all,
>> I am reading some matrices into petsc, but some of the diagonal entries are
>> really small, on the order of e-8. Petsc complains about missing diagonal
>> entries, I guess it compares them with some predefined tolerance value, is
>> there a way to change/set these tolerances?
>> Error is "Matrix is missing diagonal entry 1847!" after read from a matrix
>> market formatted text file.
>> Best regards,
>> Umut
> sorry that I forgot to explain my problem completely, I get this error when I
> try to use Slepc's EPSSolve function, so that the question is also related to
> Slepc I guess. I mean the tolerancing issues for the matrices.
