The solver doesn't converge
Yixun Liu
enjoywm at cs.wm.edu
Wed Apr 8 17:08:29 CDT 2009
I build a finite element system and the related PETSc codes are following,
KSPSetOperators(ksp,sparseMechanicalStiffnessMatrix,sparseMechanicalStiffnessMatrix,DIFFERENT_NONZERO_PATTERN);
KSPSetTolerances(ksp,0.001,1.e-50,PETSC_DEFAULT, PETSC_DEFAULT);
I output the solution and find its magnitude is about 1.0e+10. It's
definitely wrong. The correct solution should be around 1 or 2. It
seems the solver cannot converge. How do deal with this issue?
Thanks.
Yixun
