ksp parallel excecution, question on ex5 ksp tutorials
Pierre-Yves Aquilanti
sperif at gmail.com
Thu Apr 2 05:28:49 CDT 2009
Hello,
i had a few questions on the ex5 tutorial of ksp. It is described as a
parallel execution of two ksp. Does it mean that each ksp solve is running
on a single processor or the both are running in parallel on both processors
(on the cas mpirun -np 2) ? Because i don't really see the distinction with
ex2 of the same tutorial.
If it's not running two ksp in parallel, each on a single processor (in
ex5), is it possible to do that anyway ? Would i need to directly use MPI or
is there is any Petsc way to do that ?
Thank you very much for your time.
Best Regards
PYA
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090402/f09f10d3/attachment.htm>
