how to load a matlab matrix?
Barry Smith
bsmith at mcs.anl.gov
Fri Sep 26 11:27:38 CDT 2008
I do not understand your question.
You can use the PETSc binary viewer to move matrices/vectors back
and forth between PETSc and Matlab.
Barry
On Sep 26, 2008, at 10:40 AM, zhifeng sheng wrote:
> Barry Smith wrote:
>> On Sep 26, 2008, at 10:19 AM, zhifeng sheng wrote:
>>> Dear all
>>> I know that Petsc can print a matrix in matlab format. can it read
>>> a matlab format matrix? (in the same format, it prints?)
>> No, if you want to read/write for Matlab you should use the
>> binary format. The Matlab programs
>> in bin/matlab/PetscBinaryRead/Write.m are for use in Matlab.
>> Reason: the ASCII format for reading/writing is VERY slow for
>> larger matrices. The binary format is fast.
>> Barry
>>> I check Matload, and it does not work.
>>> Thanks a lot
>>> best regards
>>> Zhifeng
> But I am a matlab script as big as 1.2 G, and matlab can not handle
> it....
> I am hoping by putting it in petsc, I can do something with it.
> Any suggestions?
> thanks
> Zhifeng
