User-difined PC
Barry Smith
bsmith at mcs.anl.gov
Mon Sep 22 11:18:38 CDT 2008
On Sep 22, 2008, at 11:14 AM, Dave May wrote:
> Having the first argument for PCSHELL operations being PC sounds
> great.
> That's in keeping with the petsc pattern of the first argument being
> the object being manipulated.
> Then users just call PCShellGetContext() within their user defined
> operations.
I think one of the motivators for the current approach is usage
from Fortran 77.
PCShellGetContext() cannot return much of anything in Fortran 77, not
even an array :-(
while an array can be passed into the PCApply etc Fortran
implementations directly
as the first argument.
This is unlikely to be a good enough reason for keeping the
current form,
especially since Fortran 90 has some (not perfect) alternatives.
Barry
> On Tue, Sep 23, 2008 at 2:08 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> On Sep 22, 2008, at 7:59 AM, Dave May wrote:
>>> Why is the first pointer in PCSHELL operations the user context
>>> whereas in MATSHELL the first pointer is of type Mat ?? Seems
>>> slightly
>>> inconsistent.
>> Good question, these were done at different times and only later
>> did we realize the inconsistency. This is something that should be
>> fixed in
>> petsc-dev.
>> Barry
>> I guess the first argument for the PCSHELL should become the pc.
>>> On Mon, Sep 22, 2008 at 8:31 PM, Michel Cancelliere
>>> <fernandez858 at gmail.com> wrote:
>>>> Hello,
>>>> I have problems with the implementation of a user-defined pc,
>>>> basically
>>>> my
>>>> program is in a cycle, for with which he is called by matlab each
>>>> time it
>>>> seeks to solve a linear system, the problem is that in the first
>>>> iteration
>>>> of the for-cycle the preconditioner works very well, then fails to
>>>> convergence. It may be some parameters that I setting wrong?
>>>> I'am attaching my program code.
>>>> Thank you,
>>>> Michel
