Petsc solver question
Nguyen, Hung V ERDC-ITL-MS
Hung.V.Nguyen at usace.army.mil
Thu Sep 18 16:51:08 CDT 2008
Hello Matt,
Thank you for your answer. I rerun with using jacobi and got the result.
-Hung
-----Original Message-----
From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] On
Behalf Of Matthew Knepley
Sent: Thursday, September 18, 2008 1:58 PM
To: petsc-users at mcs.anl.gov
Subject: Re: Petsc solver question
On Thu, Sep 18, 2008 at 1:31 PM, Nguyen, Hung V ERDC-ITL-MS
<Hung.V.Nguyen at usace.army.mil> wrote:
> All,
> I have a test code that reads matrix in CSR format, rhs and provided
> solution. I run this code on Cray XT3 system with 1, 2, 4, 8 and 16 cores.
> The timing spent on KSP are 53.50, 213.69, 110.43, 66.90, and 35.60
> secs for 1, 2, 4, 8, and 16 cores; respectively. Why is a running time
> on 1 core smaller than others (2, 4, 8 cores)? Does re-ordering of
> matrix help? Did I do something wrong in the code?
It appears that you are using Block-Jacobi ILU(0). This is a completely
different preconditioner for each different number of processes.
Matt
> Thanks for your help.
> Note: the matrix, rhs, provided and computed solution are written to
> matlab files via petsc functions. It seems to me that we got the right
> solution (using matlab to verify). Then, Here is some info about matrix A:
> hvnguyen:sapphire01% head matrix.m
> % Size = 59409 59409
> % Nonzeros = 1113875
> zzz = zeros(1113875,3);
>>> cond (Mat_0)
> Warning: Using CONDEST instead of COND for sparse matrix.
>> In cond at 28
> ans =
> 3.9310e+09
> -- 1 pes:
> hvnguyen:sapphire09% yod -np 1 ./test_matrix -ksp_type cg -pc_type
> bjacobi -ksp_rtol 1.0e-15 -ksp_max_it 50000
> yod: -sz is 1, so -proc is reset from VN to 0 reading nlrn ...
> reading lrn ...
> reading cmatrix and rld ...
> Number of iterations and Time in PETSc solver = 2603
> 53.50315904617310 secs
> 2 norm of the error from the provided & computed solution =
> 3.2424850631419981E-008
> Maximum error from the provided & computed solution (infinity norm) =
> 6.1342397827957029E-010
> 1 norm of the error from the provided & computed solution
> 4.8108500117322262E-006
> -- 2 pes:
> hvnguyen:sapphire09% yod -np 2 ./test_matrix -ksp_type cg -pc_type
> bjacobi -ksp_rtol 1.0e-15 -ksp_max_it 50000 reading nlrn ...
> reading lrn ...
> Number of iterations and Time in PETSc solver = 17934
> 213.6974561214447 secs
> 2.4050101709163445E-008
> 4.5970760531588439E-010
> 3.0008169642927509E-006
> FORTRAN STOP
> -- 4 peshvnguyen:sapphire09% yod -np 4 ./test_matrix -ksp_type cg
> -pc_type bjacobi -ksp_rtol 1.0e-15 -ksp_max_it 50000 reading nlrn ...
> reading lrn ...
> Number of iterations and Time in PETSc solver = 19363
> 110.4340059757233 secs
> 1.5643187342954139E-008
> 3.4082958677572606E-010
> 2.0655232735563973E-006
> --- 8 pes
> hvnguyen:sapphire09% yod -np 8 ./test_matrix -ksp_type cg -pc_type
> reading lrn ...
> Number of iterations and Time in PETSc solver = 25953
> 66.90357208251953 secs
> 2.0977543976205624E-008
> 4.0076741925076931E-010
> 2.6098351291261861E-006
> --- 16 pes
> hvnguyen:sapphire09% yod -np 16 ./test_matrix -ksp_type cg -pc_type
> reading lrn ...
> Number of iterations and Time in PETSc solver = 25842
> 35.60693192481995 secs
> 1.5121379940662423E-008
> 3.1954527912603226E-010
> 2.0324863426877444E-006
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
