Petsc solver question
Nguyen, Hung V ERDC-ITL-MS
Hung.V.Nguyen at usace.army.mil
Thu Sep 18 13:31:05 CDT 2008
All,
I have a test code that reads matrix in CSR format, rhs and provided
solution. I run this code on Cray XT3 system with 1, 2, 4, 8 and 16 cores.
The timing spent on KSP are 53.50, 213.69, 110.43, 66.90, and 35.60 secs for
1, 2, 4, 8, and 16 cores; respectively. Why is a running time on 1 core
smaller than others (2, 4, 8 cores)? Does re-ordering of matrix help? Did I
do something wrong in the code?
Thanks for your help.
Note: the matrix, rhs, provided and computed solution are written to matlab
files via petsc functions. It seems to me that we got the right solution
(using matlab to verify). Then, Here is some info about matrix A:
hvnguyen:sapphire01% head matrix.m
% Size = 59409 59409
% Nonzeros = 1113875
zzz = zeros(1113875,3);
>> cond (Mat_0)
Warning: Using CONDEST instead of COND for sparse matrix.
> In cond at 28
ans =
3.9310e+09
-- 1 pes:
hvnguyen:sapphire09% yod -np 1 ./test_matrix -ksp_type cg -pc_type bjacobi
-ksp_rtol 1.0e-15 -ksp_max_it 50000
yod: -sz is 1, so -proc is reset from VN to 0
reading nlrn ...
reading lrn ...
reading cmatrix and rld ...
Number of iterations and Time in PETSc solver = 2603
53.50315904617310 secs
2 norm of the error from the provided & computed solution =
3.2424850631419981E-008
Maximum error from the provided & computed solution (infinity norm) =
6.1342397827957029E-010
1 norm of the error from the provided & computed solution
4.8108500117322262E-006
-- 2 pes:
hvnguyen:sapphire09% yod -np 2 ./test_matrix -ksp_type cg -pc_type bjacobi
-ksp_rtol 1.0e-15 -ksp_max_it 50000 reading nlrn ...
reading lrn ...
Number of iterations and Time in PETSc solver = 17934
213.6974561214447 secs
2.4050101709163445E-008
4.5970760531588439E-010
3.0008169642927509E-006
FORTRAN STOP
-- 4 peshvnguyen:sapphire09% yod -np 4 ./test_matrix -ksp_type cg -pc_type
bjacobi -ksp_rtol 1.0e-15 -ksp_max_it 50000 reading nlrn ...
reading lrn ...
Number of iterations and Time in PETSc solver = 19363
110.4340059757233 secs
1.5643187342954139E-008
3.4082958677572606E-010
2.0655232735563973E-006
--- 8 pes
hvnguyen:sapphire09% yod -np 8 ./test_matrix -ksp_type cg -pc_type bjacobi
reading lrn ...
Number of iterations and Time in PETSc solver = 25953
66.90357208251953 secs
2.0977543976205624E-008
4.0076741925076931E-010
2.6098351291261861E-006
--- 16 pes
hvnguyen:sapphire09% yod -np 16 ./test_matrix -ksp_type cg -pc_type bjacobi
reading lrn ...
Number of iterations and Time in PETSc solver = 25842
35.60693192481995 secs
1.5121379940662423E-008
3.1954527912603226E-010
2.0324863426877444E-006
Desc: test_matrix.F
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080918/a4cf9928/attachment.obj>
