About SNES solver of TS objects
Hong Zhang
hzhang at mcs.anl.gov
Tue Sep 16 22:06:27 CDT 2008
TSGetSNES() must be called after TSSetType(),
otherwise the nonlinear context 'snes' is
being created.
Attached please find updated ex7.c, which
illustrates how to set uer-defined SNESMonitor().
This example is pushed to petsc-dev.
I also added an error flag in petsc-dev to prevent
calling of TSGetSNES() before TSSetType().
Thanks for reporting the problem!
Best,
Hong
On Fri, 12 Sep 2008, tsjb00 wrote:
> Many thanks for your reply! The code I tried was very similar to the code in:
> ts/examples/tutorials/ex7.c
> except that I changed the r.h.s. function.
> The code related to TS:
> ierr = TSCreate(PETSC_COMM_WORLD,&ts);CHKERRQ(ierr);
> ierr = TSSetProblemType(ts,TS_NONLINEAR);CHKERRQ(ierr);
> ierr = TSSetRHSFunction(ts,FormFunction,&appctx);CHKERRQ(ierr);
> ierr = DAGetColoring(appctx.da,IS_COLORING_GLOBAL,&iscoloring);CHKERRQ(ierr);
> ierr = MatFDColoringCreate(J,iscoloring,&matfdcoloring);CHKERRQ(ierr);
> ierr = ISColoringDestroy(iscoloring);CHKERRQ(ierr);
> ierr = MatFDColoringSetFunction(matfdcoloring,(PetscErrorCode (*)(void))FormFunction,&appctx);CHKERRQ(ierr);
> ierr = MatFDColoringSetFromOptions(matfdcoloring);CHKERRQ(ierr);
> ierr = TSSetRHSJacobian(ts,J,J,TSDefaultComputeJacobianColor,matfdcoloring);CHKERRQ(ierr);
> dt = appctx.dtmin;
> ierr = TSSetInitialTimeStep(ts,0.0,dt);CHKERRQ(ierr);
> ierr = TSSetType(ts,TS_BEULER);CHKERRQ(ierr);
> Then I tried to add the snes monitor:
> PetscViewerASCIIOpen(PETSC_COMM_WORLD,"snes.log",&rviewer);
> ierr = TSGetSNES(ts,&ts_snes);
> ierr = SNESMonitorSet(ts_snes,SNESMonitorDefault,&rviewer,PETSC_NULL);
> I got the snes.log with long lines which started with countless blank/space and ended at the very end with the SNES iteration info. As a result, the file took a lot of memory space even with one line of outputs.
> Please let me know if I did something wrong.
> Have a nice weekend!
> _________________________________________________________________
> аæÊÖ»úMSN£¬Âú×ãÄã¶à²ÊÐèÇ󣡲μÓÇÀÏÊÌåÑé»î¶¯£¬ÁìÈ¡ÌØÉ«½±Æ·£¡
> http://mobile.msn.com.cn/
Type: text/x-csrc
Desc: ex7.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080916/66422e64/attachment.c>
