About SNES solver of TS objects
tsjb00
tsjb00 at hotmail.com
Thu Sep 11 18:47:01 CDT 2008
Hi!
I use TS object to solve a non-linear problem du/dt=f(u,t). I would like to check the non-linear solver performance in TSStep. I tried to output the residuals by setting a monitor. So far my attempt didn't work. Please let me know if there are functions that calculate residuals of iterations in each TS time step. If not, how can I output the solver iteration/residuals correctly while using TS objects.
Many thanks!
P.S. The following are the code I tried:
PetscViewerASCIIOpen(PETSC_COMM_WORLD,"snes.log",&rviewer);
ierr = TSGetSNES(ts,&ts_snes);
ierr = SNESMonitorSet(ts_snes,SNESMonitorDefault,&rviewer,PETSC_NULL);
I did get residual output in snes.log, but the format was very weird. Each line started with countless blank/space and at the very end was the SNES iteration info. As a result, the file took a lot of memory space even with one line of outputs.
I also tried:
PetscViewerASCIIMonitorCreate(PETSC_COMM_WORLD,"snes.log",0,&rviewer);
which didn't work at all.
_________________________________________________________________
一点即聊,MSN推出新功能“点我!”
http://im.live.cn/click/
