Matrix blocks
Tue Sep 9 07:26:26 CDT 2008
   From the manual page:
    This routine creates the matrices in submat; you should NOT create
them before
    calling it. It also allocates the array of matrix pointers submat.
   You should declare Mat *submat; // no 4 here
   then pass &submat into the function call
   Also note note from the manual page:
   MatGetSubMatrices() can extract ONLY sequential submatrices
    (from both sequential and parallel matrices). Use MatGetSubMatrix()
    to extract a parallel submatrix.
     Perhaps you really want to use MatGetSubMatrix()? Or perhaps you
want to
use the PCFIELDSPLIT preconditioner that is in petsc-dev http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
    Barry
On Sep 9, 2008, at 7:05 AM, Michel Cancelliere wrote:
> Ok, I'm using MatGetSubMatrix() with the following piece of code
> PetscErrorCode SampleShellPCSetUp(SampleShellPC *shell,Mat pmat,Vec x)
>   Mat            *submat[4];
>   PetscErrorCode ierr;
>   PetscInt       N;
>   IS             set1[4],set2[4];
>   ierr = VecGetSize(x,&N);CHKERRQ(ierr);
>   ierr = ISCreateStride(PETSC_COMM_SELF,N/
> 2,0,1,&set1[0]);CHKERRQ(ierr);
> 2,0,1,&set2[0]);CHKERRQ(ierr);
> 2,0,1,&set1[1]);CHKERRQ(ierr);
>   ierr = ISCreateStride(PETSC_COMM_SELF,N/2,N/
> 2,1,&set2[1]);CHKERRQ(ierr);
> 2,1,&set1[2]);CHKERRQ(ierr);
> 2,0,1,&set2[2]);CHKERRQ(ierr);
> 2,1,&set1[3]);CHKERRQ(ierr);
> 2,1,&set2[3]);CHKERRQ(ierr);
>   ierr = MatGetSubMatrices(pmat,
> 4,set1,set2,MAT_INITIAL_MATRIX,submat);CHKERRQ(ierr);
> but it seems to get only the first of the subblocks,
> am I using the correct syntax for the MatGetSubMatrices function?
> Thank you
> On Fri, Sep 5, 2008 at 2:42 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> You can extract matrix blocks using MatGetSubMatrix().
>   Matt
> On Fri, Sep 5, 2008 at 6:50 AM, Michel Cancelliere
> <fernandez858 at gmail.com> wrote:
> > Hi All,
> > I am building a shell preconditioner, for implement that I should
> divide a
> > sparse matrix into four blocks of dimension N/2xN/2 (N size of the
> Matrix),
> > I took a look to src/mat/examples/tutorials/ex2 but it is for
> dense matrix.
> > There is a function for do that in Petsc? or another method for
> efficiently
> > implementation?
> > Thank you,
> > Michel Cancelliere
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
