ILU for MatAIJ
Tim Kroeger tim.kroeger at cevis.uni-bremen.de
Thu Nov 13 05:22:42 CST 2008
Dear PETSc team,
In my application, I got this (on 4 CPUs):
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: Matrix type mpiaij  symbolic ILU!
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Release Version 2.3.3, Patch 11, Thu Mar 27 09:16:38 CDT 2008 HG revision: 0a79e1469a317b0468b3b3310524bf13867c66f5
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./checkConvergence on a linux-gnu named inf056 by tkroger Thu Nov 13 04:06:32 2008
[0]PETSC ERROR: Libraries linked from /home/collab/tkroger/packages/petsc-2.3.3-p11/lib/linux-gnu-c-debug
[0]PETSC ERROR: Configure run at Fri Oct 17 06:57:08 2008
[0]PETSC ERROR: Configure options --with-mpi-dir=/usr/local/lam-mpi/ --with-mpi-compilers=1 --download-f-blas-lapack=1 --with-shared=0
[0]PETSC ERROR: MatILUFactorSymbolic() line 4788 in src/mat/interface/matrix.c
[0]PETSC ERROR: PCSetUp_ILU() line 541 in src/ksp/pc/impls/factor/ilu/ilu.c
[0]PETSC ERROR: PCSetUp() line 787 in src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPSetUp() line 234 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: KSPSolve() line 347 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: User provided function() line 687 in unknowndirectory/src/numerics/petsc_linear_solver.C
I wonder what that means because the AIJ matrix type should be able to
do ILU preconditioning, shouldn't it?  In other words: If not, which
matrix type will then be able to do that?
Best Regards,
Tim
Dr. Tim Kroeger                                        Phone +49-421-218-7710
tim.kroeger at mevis.de, tim.kroeger at cevis.uni-bremen.de  Fax   +49-421-218-4236
MeVis Research GmbH, Universitaetsallee 29, 28359 Bremen, Germany
Amtsgericht Bremen HRB 16222
Geschaeftsfuehrer: Prof. Dr. H.-O. Peitgen
