ksp_monitor and hypre/boomeramg
Shao-Ching Huang
schuang at ats.ucla.edu
Wed Nov 12 11:44:21 CST 2008
Hi Matt:
I tried "-ksp_converged_reason" you suggested. With "-ksp_monitor", it
shows "due to CONVERGED_RTOL". Without "-ksp_monitor", it shows "due
to CONVERGED_ITS".
$ mpiexec -np 1 -machinefile mach ./ibm -ksp_type richardson \
-pc_type hypre -pc_hypre_type boomeramg -ksp_monitor \
-ksp_converged_reason | grep Linear
Linear solve converged due to CONVERGED_RTOL iterations 5
-pc_type hypre -pc_hypre_type boomeramg \
Linear solve converged due to CONVERGED_ITS iterations 0
Shao-Ching
On Tue, Nov 11, 2008 at 07:45:11PM -0600, Matthew Knepley wrote:
> Nothing should change. You can try -ksp_converged_reason to see why it
> terminates. The best way is to put a breakpoint in KSPDefaultConverged()
> and check the convergence test.
> Matt
