Running petsc on infiniband
Saswata Hier-Majumder saswata at umd.edu
Sat Nov 1 16:00:35 CDT 2008
Thanks. Using FFLAGS=-nochoicemod seemed to take care of most of the
error messages in the configure.log file, but the original problem still
persists.
Satish Balay wrote:
> On Sat, 1 Nov 2008, Saswata Hier-Majumder wrote:
>> Satish,
>> Thanks for the prompt response!
>> After rerunning the installation script with the correct path, I found a bunch
>> of error messages in the configure.log file which look like
>> sh: /opt/vltmpi/OPENIB/mpi.icc.rsh/bin/mpif90 -o conftest conftest.o
>> Executing: /opt/vltmpi/OPENIB/mpi.icc.rsh/bin/mpif90 -o conftest conftest.o
>> sh:
>> Possible ERROR while running linker: /opt/intel/fce/10.0.023/lib/libimf.so:
>> warning: warning: feupdateenv is not implemented and will always fail
>> I recognize the last part of the error message. I need to use the option
>> -nochoicemod while compiling an mpi code with mpif90 to avoid this error. Is
>> there any way for me to pass that option to the petsc installer? I tried
>> --with-fc=mpif90 -nochoicemod
>> in the install shell script, but that did not seem to work.
> -with-fc="mpif90 -nochoicemod" should work. Alternatively you can use FFLAGS=-nochoicemod
> Satish
www.geol.umd.edu/~saswata
