Solving 2 eqns at the same time in PETSc
Ben Tay zonexo at gmail.com
Fri May 30 17:33:03 CDT 2008
(I sent this email a while ago but I use a different email address. Not
sure if it got through since it's not registered in the server list.
Sorry if it was resent.)
I obtain 2 linear eqns (u and v velocity) from the momentum eqn in my
CFD code. Instead of solving eqn 1 in parallel, and then subsequently
eqn 2 in parallel, I am thinking of solving the 2 eqns at the same time,
using half the number of processors on each eqn. In other words, when
using 4 processors, I use 2 processors for eqn 1 and 2 processors for
eqn 2. Will that be possible?
I thought that in MPI, if an equation is divided among too many
processors, its scaling factor will decrease. So by dividing into less
processors and solving them simultaneously, it will give better
performance. Is that true?
I've also successfully coded 1 eqn to be solved in parallel in PETSc.
What changes do I have to made now?
Thank you very much.
Regards.
