problem of parallel MatAssembled
    Gong Ding
    gdiso at ustc.edu
    Fri May 30 10:19:32 CDT 2008
I use MatAssembled to determine if a parallel matrix (MPIAIJ) is assembled.
One processor says 1 and another says 0. (Petsc-2.3.3-p2)
The correct answer should be the same for all the processor  I think.
Is it a bug or I forget something?
BTW. I think a function as MatAddRowToRow is useful.
I had implemented with MatGetRow and MatSetValues (or use Mat*Mat?).
However, write it from lower level should be more efficient.
If the develops can add this to petsc...
Regards
Gong Ding
