MatMerge_SeqsToMPI
Tue May 20 15:49:15 CDT 2008
Is there a reason not to assemble the whole system at once? This is usually
much easier. You can even use the same indices with MatSetValuesLocal().
  Matt
On Tue, May 20, 2008 at 3:16 PM, Waad Subber <w_subber at yahoo.com> wrote:
> Thank you Matt,
> Any suggestion to solve the problem I am trying to tackle. I want to solve a
> linear system:
> Sum(A_i) u= Sum(f_i) , i=1.... to No. of CPUs.
> Where  A_i is a sparse sequential matrix and f_i is a sequential vector.
> Each CPU has one matrix and one vector of the same size. Now I want to sum
> up and solve the system in parallel.
> Thanks again
> Waad
> Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 20, 2008 at 2:12 PM, Waad Subber wrote:
>> Hi,
>> I am trying to construct a sparse parallel matrix (MPIAIJ) by adding up
>> sparse sequential matrices (SeqAIJ) from each CPU. I am using
>> MatMerge_SeqsToMPI(MPI_Comm comm,Mat seqmat,PetscInt m,PetscInt n,MatReuse
>> scall,Mat *mpimat)
>> to do that. However, when I compile the code I get the following
>> undefined reference to `matmerge_seqstompi_'
>> collect2: ld returned 1 exit status
>> make: *** [all] Error 1
>> Am I using this function correctly ?
> These have no Fortran bindings right now.
> Matt
>> Thanks
>> Waad
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
-- Norbert Wiener
