SV: Subject: Parallel petsc with external UMFPACK
Lars Rindorf Lars.Rindorf at teknologisk.dk
Tue May 13 11:40:03 CDT 2008
Hi Satish
I'm sorry. My text should have read, that UMFPACK is listed as not available in parallel. My fault.
MUMPS sounds very interesting being a multifrontal solver. I'll try it out. Thanks!
KR, Lars
-----Oprindelig meddelelse-----
Fra: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] På vegne af Satish Balay
Sendt: 13. maj 2008 18:07
Til: petsc-users at mcs.anl.gov
Emne: Re: Subject: Parallel petsc with external UMFPACK
> From: "Lars Rindorf" <Lars.Rindorf at teknologisk.dk>
> To: <petsc-users at mcs.anl.gov>
> I'm thinking about using petsc to solve a linear system (Ax=b) using
> parallelization on a couple of linux computers. It is very important
> for my system (electromagnetics) to use a direct solver, such as UMFPACK.
> Iterative solvers perform very poorly.
> My question is:  I can see that UMFPACK is not listed
> (http://www-unix.mcs.anl.gov/petsc/petsc-2/documentation/linearsolvert
> ab
> le.html) on the petsc page. Are there any plans to expand petsc to
> also include petsc?
Its listed there. However it says parallel/complex support is not available.
However - if you need a parallel direct solver - you might explore MUMPS. The other alternatives are SuperLU_DIST, spooles.
Satish
> The UMFPACK homepage says that there exist a parallization for UMFPACK
> by Steve Hadfield. Can his parallelization be used with petsc?
> I must add, that although I like numerics and maths I do not intend to
> program 'from scratch'.
> Kind regards
> Lars Rindorf
