Selection between C2D and Xeon 3000 for PETSc Sparse solvers
amjad ali amjad11 at gmail.com
Fri May 2 11:12:20 CDT 2008
Hello Dr. Satish, I am still bit confused in taking decesion and wanting
some more guidence from you and PETSc users/maint.
*Question ONE:*
Please help me in selecting out one of the following two clusters, *bit
updated/changed from my previous choices.*
As I am going to make a gigabit ethernet cluster of 4 compute nodes
(totaling 8 cores), with each node having:
(Choice 1)
One Processor: Intel Core2Duo E6750 2.66GHz, FSB 1333MHz, 4MB L2.
Motherboard: Intel Desktop Board DX38BT with Intel X38 Chipset supporting
1333/1066/800 MHz system bus.
RAM: 2GB DDR3 1333MHz ECC System Memory.
(Choice 2)
One Processor: Intel Xeon 3075 2.66GHz, FSB1333, 4MBL2.
Motherboard: Intel Entry Server Board Intel S3200SHV with intel 3200 Chipset
supporting 1333/1066/800 MHz system bus.
RAM: 2GB DDR2 800MHz ECC System Memory.
Which one system has larger memory-bandwidth/CPU-core? Better for PETSc?
Any other comment/remark?
My area work deals in sparse matrices.
I near future I would like to add 12 similar compute nodes in the cluster.
So my decision should be optimum/long-lasting.
*Question TWO:*
I want to make ROCKS V cluster on Intel x86_64 machines (selected from the
above options). ROCKS V is available separately for both i386 and x86_64
machines. But I have not seen two different version of PETSc for i386 and
x86_64 machines.
Is there only a single version for PETSc for both i386 and x86_64 machines?
IF YES, then out of "ROCKS/OS i386" and "ROCKS/OS x86_64" which one is more
suitable (efficiecy/speed/performance wise) for PETSc?
Amjad Ali.
On Tue, Apr 22, 2008 at 8:25 PM, Satish Balay <petsc-maint at mcs.anl.gov>
wrote:
>  On Tue, 22 Apr 2008, amjad ali wrote:
> >  Hello,
> > Please help me out in selecting any one choice of the following:
> >  (Currently I am making a gigabit ethernet cluster of 4 compute nodes
> > (totaling 8 cores), with each node having)
> > (Choice 1)
> > One Processor: Intel Core2Duo E6750 2.66 GHz Processor, FSB 1333MHz, 4MB
> L2.
> Chipset
> > supporting 1333/1066/800 MHz FSB .
> > (Choice 2)
> > One Processor: Intel Xeon 3075 2.66 GHz FSB1333 4MBL2.
> > Chipset supporting 1333/1066/800 MHz FSB .
> cluster.
> Based on the above numbers - the memory bandwidth numbers should be
> the same. And I expect the performance to be the same in both cases.
> Ideally you would have access to both machines [perhaps from the
> vendor] - and run streams benchmark on each - to see if there is any
> difference.
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080502/bf6c7500/attachment.htm>
