out of memory error
li pan
li76pan at yahoo.com
Thu Mar 6 01:36:04 CST 2008
hi Gideon,
can I ask you how big is the nonzero allocation of
your sparse matrix?
pan
--- Gideon Simpson <grs2103 at columbia.edu> wrote:
> I'm getting the following error with some code,
> running on a serial
> machine with, i think, 3 gigs of memory. Is there
> anyway to
> circumvent this error by being clever, or do I
> really need to go to a
> distributed memory machine?
> -gideon
> Out of memory trying to allocate 112032952 bytes
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 10 BUS: Bus
> Error, possibly
> illegal memory access
> [0]PETSC ERROR: Try option -start_in_debugger or -
> on_error_attach_debugger
> [0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal
> [0]PETSC ERROR: or try http://valgrind.org on linux
> or man libgmalloc
> on Apple to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in
> stack below
> [0]PETSC ERROR: --------------------- Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the
> stack are not
> available,
> [0]PETSC ERROR: INSTEAD the line number of the
> start of the
> function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] PCSetUp_HYPRE line 95
> src/ksp/pc/impls/hypre/hypre.c
> [0]PETSC ERROR: [0] PCSetUp line 764
> src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: [0] KSPSetUp line 183
> src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] KSPSolve line 305
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 2.3.3, Patch
> 8, Fri Nov 16
> 17:03:40 CST 2007 HG revision:
> 414581156e67e55c761739b0deb119f7590d0f4b
> [0]PETSC ERROR: See docs/changes/index.html for
> recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about
> trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual
> pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./bulk3d on a darwin8.1 named
> valkyrie.appmath.columbia.edu by gideon Wed Mar 5
> 15:53:26 2008
> [0]PETSC ERROR: Libraries linked from
> /Users/gideon/software/
> petsc-2.3.3-p8/lib/darwin8.11.1-cxx-debug
> [0]PETSC ERROR: Configure run at Thu Jan 10 11:00:45
> 2008
> [0]PETSC ERROR: Configure options
> --with-clanguage=cxx --with-mpi-dir=/
> Users/gideon/software --with-mpi-shared=1 --with-x11
> --download-
> hypre=1 --with-hypre=1 --download-umfpack=1
> --with-umfpack=1 --with-
> shared=1 --with-dynamic=1
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in
> unknown directory
> unknown file
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
