question about Petsc_Real
Satish Balay
balay at mcs.anl.gov
Wed Jun 11 16:08:17 CDT 2008
On Wed, 11 Jun 2008, tsjb00 wrote:
> Have a stupid question about the precision of Petsc_Real (float, double, long double...)
> Is it defined when installing the PETSC package? How?
yes with the configure option --with-precision=double. However -
precisions other than double are not well tested.
> Once the PETSC is installed, can I still change the precision of
> Petsc_Real for different application code? How?
nope.
> Do I have to recompile the PETSC package?
yes you have to recompile. However you can use a different PETSC_ARCH
for this build - so that both builds are useable. [you can switch
between them by using the correct PETSC_ARCH value with make - when
compiling your code]
Satish
