Performance Log Question
Waad Subber w_subber at yahoo.com
Thu Jul 31 22:09:10 CDT 2008
Thank you Barry for the replay. Yes I get more or less the same log when I run with the option -log_summary. Please have a look at the attached file.
Thanks
Waad
--- On Thu, 7/31/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
Subject: Re: Performance Log Question
To: petsc-users at mcs.anl.gov
Date: Thursday, July 31, 2008, 9:27 PM
   From the file, it seems you never make an nontrivial PETSc calls.
Do you get the same
log if you just run with -log_summary?
    Barry
Event                Count      Time (sec)     Flops/
sec                         --- Global ---  --- Stage ---   Total
                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
On Jul 31, 2008, at 4:33 PM, Waad Subber wrote:
> Hello,
> I am currently solving a 1.2 million by 1.2 million linear system
> using PETSc 2.3.3, Patch 13 using domain decomposition (iterative
> substructuring using a Krylov Subspace Solver). I'm using a 120 CPU
> cluster with InfiniBand interconnect; each node has 8 cores -- 2
> quad-core Xeon CPUs (X5365) at 3.0 GHz, each node having 32 GB of RAM.
> After running my code, I generate a log using the following:
>        CALL
PetscLogPrintSummary(PETSC_COMM_WORLD,"log.txt",ierr)
> When looking at the log output, I noticed that the peak and average
> number of Flops seems fairly low -- in the case of one run, a peak
> of 6.0e7 flops with an average value of 5.2e7. The exact log output
> is:
>                          Max       Max/Min        Avg      Total
> Time (sec):           5.283e+01      1.02357   5.169e+01
> Objects:              2.600e+02      1.00000   2.600e+02
> Flops:                3.187e+09      1.69853   2.721e+09  3.265e+11
> Flops/sec:            6.165e+07      1.69865   5.264e+07  6.317e+09
> Memory:               6.081e+07      1.39801              6.608e+09
> MPI Messages:         1.067e+05      1.00000   1.067e+05  1.281e+07
> MPI Message Lengths:  5.205e+08      1.00081   4.875e+03  6.245e+10
> MPI Reductions:       1.898e+01      1.00000
> Is my interpretation correct about this being a fairly low flop
> count? Does this mean there's an issue with my code?
> I am attaching my log file
> Thanks
> Waad
> <log.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080731/4f92c48c/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080731/4f92c48c/attachment.obj>
