Puzzling error
Kevin Ellwood kellwood at ameritech.net
Sat Jul 26 10:40:52 CDT 2008
Ah.  I think I have confused you guys.  I am using the most recent version
pf Petsc (ie. 2.3.3 p13).  I am trying to get my old code (which I made
using 2.0.22) up and running.  I have updated most everything and I am
trying to run for the first time.  Given what you said, I am guessing that I
have messed up in a way the causes KSPRegisterAll and KSPRegister not to be
called.
Thanks
Kev
On Sat, Jul 26, 2008 at 10:14 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jul 25, 2008 at 8:56 PM, Kevin Ellwood <kellwood at gmail.com> wrote:
> > Hi and thanks.  Are there any example for the usage of these calls?
> There is not really a "usage". They are supposed to be called automatically
> and you never know. However, when using ancient versions of petsc,
> sometimes
> things go wrong. I really encourage upgrading to the latest version.
>  Thanks,
>     Matt
> > On Fri, Jul 25, 2008 at 5:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>  Kevin,
> >>   Make sure KSPRegisterAll() is called and that KSPRegister() is called
> >> specifically for KSPGMRES
> >>   Barry
> >> On Jul 25, 2008, at 4:12 PM, Kevin Ellwood wrote:
> >>> Hi All,
> >>> I am trying to resurrect an old FEM code of mine that was based on a
> very
> >>> early version of PETSC (ie. 2.0.x).  I am go through all the changes
> and I
> >>> am pretty sure I have some issue to get through.  However, this set of
> >>> errors below from an early test run are puzzling me.  The relevant
> lines of
> >>> code are shown for setting two type of solvers.  Both generate an error
> >>> message indicating the Petsc can't find the KSP type once the KSPSolve
> is
> >>> called.   It seems odd that I can get such an error since  KSPBCGS and
> >>> KSPGMRES are define in petsc header files and can't be typos or
> >>> miss-spellings.
> >>> I know I messed up somewhere.  Does anyone have advice as to where I
> >>> should start looking?
> >>> Thanks
> >>> Kevin
> >>>         KSPSetType(ksp_solver,KSPBCGS);
> >>>         ierr = KSPSolve(ksp_solver, rhs, b); CHKERRQ(ierr);
> >>> [0]PETSC ERROR: --------------------- Error Message
> >>> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing
> external
> >>> package needed for type!
> >>> [0]PETSC ERROR: Unable to find requested KSP type bcgs!
> >>>         KSPSetType(ksp_solver,KSPGMRES);
> external
> >>> [0]PETSC ERROR: Unable to find requested KSP type gmres!
> >>> [0]PETSC ERROR:
> >>> [0]PETSC ERROR: Petsc Release Version 2.3.3, Patch 3, Fri Jun 15
> 16:51:25
> >>> CDT 2007 HG revision: f051789beadcd36f77fb6111d20225e26ed7cc0d
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080726/47dfedc5/attachment.htm>
