Puzzling error
Kevin Ellwood kellwood at ameritech.net
Sat Jul 26 09:26:53 CDT 2008
Hi and thanks.  I can't really find anything in the examples and this seems
to be new since Petsc 2.0.X.  Are there any example for the usage of these
calls?
On Fri, Jul 25, 2008 at 5:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Kevin,
>   Make sure KSPRegisterAll() is called and that KSPRegister() is called
> specifically for KSPGMRES
>   Barry
> On Jul 25, 2008, at 4:12 PM, Kevin Ellwood wrote:
>  Hi All,
>> I am trying to resurrect an old FEM code of mine that was based on a very
>> early version of PETSC (ie. 2.0.x).  I am go through all the changes and I
>> am pretty sure I have some issue to get through.  However, this set of
>> errors below from an early test run are puzzling me.  The relevant lines of
>> code are shown for setting two type of solvers.  Both generate an error
>> message indicating the Petsc can't find the KSP type once the KSPSolve is
>> called.   It seems odd that I can get such an error since  KSPBCGS and
>> KSPGMRES are define in petsc header files and can't be typos or
>> miss-spellings.
>> I know I messed up somewhere.  Does anyone have advice as to where I
>> should start looking?
>> Thanks
>> Kevin
>>         KSPSetType(ksp_solver,KSPBCGS);
>>         ierr = KSPSolve(ksp_solver, rhs, b); CHKERRQ(ierr);
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing external
>> package needed for type!
>> [0]PETSC ERROR: Unable to find requested KSP type bcgs!
>>         KSPSetType(ksp_solver,KSPGMRES);
>> [0]PETSC ERROR: Unable to find requested KSP type gmres!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Release Version 2.3.3, Patch 3, Fri Jun 15 16:51:25
>> CDT 2007 HG revision: f051789beadcd36f77fb6111d20225e26ed7cc0d
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080726/b0f17a5d/attachment.htm>
