Puzzling error
Kevin Ellwood kellwood at ameritech.net
Fri Jul 25 16:12:07 CDT 2008
Hi All,
I am trying to resurrect an old FEM code of mine that was based on a very
early version of PETSC (ie. 2.0.x).  I am go through all the changes and I
am pretty sure I have some issue to get through.  However, this set of
errors below from an early test run are puzzling me.  The relevant lines of
code are shown for setting two type of solvers.  Both generate an error
message indicating the Petsc can't find the KSP type once the KSPSolve is
called.   It seems odd that I can get such an error since  KSPBCGS and
KSPGMRES are define in petsc header files and can't be typos or
miss-spellings.
I know I messed up somewhere.  Does anyone have advice as to where I should
start looking?
Thanks
Kevin
         KSPSetType(ksp_solver,KSPBCGS);
         ierr = KSPSolve(ksp_solver, rhs, b); CHKERRQ(ierr);
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Unknown type. Check for miss-spelling or missing external
package needed for type!
[0]PETSC ERROR: Unable to find requested KSP type bcgs!
         KSPSetType(ksp_solver,KSPGMRES);
[0]PETSC ERROR: Unable to find requested KSP type gmres!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 2.3.3, Patch 3, Fri Jun 15 16:51:25
CDT 2007 HG revision: f051789beadcd36f77fb6111d20225e26ed7cc0d
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080725/9c0df3fb/attachment.htm>
