CHKMEMQ
Paul T. Bauman pbauman at ices.utexas.edu
Wed Jul 23 13:31:48 CDT 2008
Thanks guys.
Barry Smith wrote:
>   To emphasis Satish's point you should definitely use
> www.valgrind.org to remove
> all the memory bugs before starting to use it with PETSc.
>   valgrind is the closest thing to a magic bullet I have ever seen in
> computing.
>    Barry
> On Jul 23, 2008, at 1:04 PM, Satish Balay wrote:
>> On Wed, 23 Jul 2008, Paul T. Bauman wrote:
>>> Hello,
>>> Quick (and probably stupid) question: Does CHKMEMQ check *all* of
>>> memory used
>>> by the program for corruption or just the memory PETSc allocated? I
>>> have a
>>> code that I'm assigned to work on that doesn't use PETSc (yet), but
>>> I was
>>> hoping to use this macro to track down what I think is a memory
>>> corruption
>>> bug.
>> CHKMEMQ checks memory allocated by PetscMalloc() - for
>> out-of-bounds-write errors.
>> Valgrind is a general tool for detecting many more types of memory
>> corruption.
>> Satish
