problem with bison
Thu Jul 17 13:49:48 CDT 2008
Can you send the make output - when you compile a PETSc example?
Satish
On Thu, 17 Jul 2008, Nicolas Flipo wrote:
> Hi Satish,
> I'm not sure to understand exactly what you mean. I tried to use the
> -I option . It seems that include works out now but I still have a
> problem with vecimpl.h
> user at linux-46jw:> make program
> bison -y  -dv  newent.y
> gcc -g -Wall -DYYDEBUG   -I/usr/local/bin/petsc-2.3.3-p13/include
> -I/usr/local/bin/petsc-2.3.3-p13/include/petsc
> -I/usr/local/bin/petsc-2.3.3-p13/include/mpiuni
> -I/usr/local/bin/petsc-2.3.3-p13/include/private
> -I/usr/local/bin/petsc-2.3.3-p13/bmake/linux-gnu-c-debug   -c -o
> newent.o y.tab.c
> In file included from /usr/local/bin/petsc-2.3.3-p13/include/petscvec.h:427,
>                 from /usr/local/bin/petsc-2.3.3-p13/include/petscmat.h:6,
>                 from /usr/local/bin/petsc-2.3.3-p13/include/petscpc.h:6,
>                 from /usr/local/bin/petsc-2.3.3-p13/include/petscksp.h:6,
>                 from function.h:27,
>                 from newent.y:166:
> /usr/local/bin/petsc-2.3.3-p13/include/private/vecimpl.h:236: error:
> expected specifier-qualifier-list before 'MPI_Win'
> newent.y: In function 'yyparse':
> newent.y:740: warning: implicit declaration of function 'calcule_pk_apports'
> newent.y:1900: warning: unused variable 'lu_fprod'
> make: *** [newent.o] Error 1
> The last thing is that I don't understand why include
> ${PETSC_DIR}/bmake/common/base doesn't work for bison?
> Nico
> On Thu, Jul 17, 2008 at 9:40 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Hmm - perhaps you need to specify a '.y.c:' target in your makefile?
> > It loks like make is using a '.y.o:' target - thus skipping '.c.o:'
> > target as defined in PETSc makefiles.
> >> gcc -g -Wall -DYYDEBUG    -c -o newent.o y.tab.c
> > If PETSc target for .c file is used - you should see
> > -I$PETSC_DIR/include etc options aswell.
> > Satish
> >> I've got a problem when compiling my code if I include petscksp.h in a *.h
> >> Here is the error message (translated in english)
> >> user at linux-46jw> make program
> >> In file included from newent.y:166:
> >> function.h:27:56: error: petscksp.h: Aucun fichier ou répertoire de ce
> >> type (no file or folder found)
> >> I have no problem to compile PETSc examples, so the environment
> >> variable PETSC_DIR is correctely set in my system.
> >> I also made a test including petscksp.h directly in the .y and it gave
> >> me exactly the same error message, that's why I am suspecting
> >> something with bison...
> >> FYI here is my Makefile:
> >> PROGRAMME= program
> >> SOURCES.c = verouille.c hydraulique.c flux_apport.c init_hyd.c        matrice.c
> >> SOURCES.l = lexique.l
> >> SOURCES.y = newent.y
> >> SOURCES.h = parametres.h structurs.h var_globals.h functions.h
> >> SOURCES.f=
> >> CFLAGS_GLOBAUX= -g -Wall -DYYDEBUG
> >> CFLAGS= $(CFLAGS_GLOBAUX)
> >> YACC= bison -y
> >> LEX= flex
> >> YFLAGS= -dv
> >> LFLAGS= -v
> >> CC=gcc
> >> OBJ= $(SOURCES.y:.y=.o) $(SOURCES.l:.l=.o) $(SOURCES.c:.c=.o)
> >> CLEANFILES = $(OBJ) core y.*
> >> include ${PETSC_DIR}/bmake/common/base
> >> $(PROGRAMME) : $(OBJ) chkopts
> >>       -$(CLINKER) -o $(PROGRAMME) $(OBJ) ${PETSC_KSP_LIB}
> >> #     ${RM} $(OBJ) #  rajouter une fois que tout marchera correctement
> >> Thanks for your help
> >> Nico
