problem with bison
Nicolas Flipo Nicolas.Flipo at ensmp.fr
Thu Jul 17 10:06:26 CDT 2008
I've got a problem when compiling my code if I include petscksp.h in a *.h
Here is the error message (translated in english)
user at linux-46jw> make program
bison -y  -dv  newent.y
gcc -g -Wall -DYYDEBUG    -c -o newent.o y.tab.c
In file included from newent.y:166:
function.h:27:56: error: petscksp.h: Aucun fichier ou répertoire de ce
type (no file or folder found)
I have no problem to compile PETSc examples, so the environment
variable PETSC_DIR is correctely set in my system.
I also made a test including petscksp.h directly in the .y and it gave
me exactly the same error message, that's why I am suspecting
something with bison...
FYI here is my Makefile:
PROGRAMME= program
SOURCES.c = verouille.c hydraulique.c flux_apport.c init_hyd.c 	matrice.c
SOURCES.l = lexique.l
SOURCES.y = newent.y
SOURCES.h = parametres.h structurs.h var_globals.h functions.h
SOURCES.f=
CFLAGS_GLOBAUX= -g -Wall -DYYDEBUG
CFLAGS= $(CFLAGS_GLOBAUX)
YACC= bison -y
LEX= flex
YFLAGS= -dv
LFLAGS= -v
CC=gcc
OBJ= $(SOURCES.y:.y=.o) $(SOURCES.l:.l=.o) $(SOURCES.c:.c=.o)
CLEANFILES = $(OBJ) core y.*
include ${PETSC_DIR}/bmake/common/base
$(PROGRAMME) : $(OBJ) chkopts
	-$(CLINKER) -o $(PROGRAMME) $(OBJ) ${PETSC_KSP_LIB}
#	${RM} $(OBJ) #  rajouter une fois que tout marchera correctement
Thanks for your help
Nico
