"Diagonal" Columns of MPIAIJ Matrix?
Barry Smith
bsmith at mcs.anl.gov
Wed Jul 2 16:43:09 CDT 2008
The code used to divide it up by default is PetscMapSetUp() in src/
vec/impls/mpi/pmap.c
Barry
On Jul 2, 2008, at 4:33 PM, Andrew Colombi wrote:
> Is it fair to say that MatPreallocateInitialize and MatPreallocateSet
> need to be in the same scope for this to work? If so, that will never
> work with my code. (Unless I can call repeatedly without having it
> reinitialize things.)
> I already had everything setup to work with my own bookkeeping (STL
> vector and binary_search, in my tests STL set took too much memory).
> But I need get the diagonal columns!
> So be it. I'm willing to hack. May I assume PETSc distributes
> columns with the following algorithm:
> int diag_cols = total_cols / processors;
> if (mpi_rank() < total_cols % processors)
> diag_cols += 1;
> Then assume the offsets follow the MPI rank? (i.e. higher rank has
> later columns)
> Thanks,
> -Andrew
> On Wed, Jul 2, 2008 at 3:34 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> On Jul 2, 2008, at 3:25 PM, Andrew Colombi wrote:
>>> Is MatGetOwnershipRangeColumn a new function?
>> Looks like it.
>>> because I don't think it
>>> I have it. I'm using petsc-2.3.3-p13. I searched petsc/include for
>>> RangeColumn and didn't find anything.
>>> I could switch over to MatPreallocateInitialize, but I'm not
>>> entirely
>>> sure how it works. The docs reference a chapter in the user manual
>>> about performance,
>>> "See the chapter in the users manual on performance for more
>>> details"
>>> But I can't find anything in the PDF manual that mentions
>>> PreallocateInitialize or PreallocateSet (I searched the text for
>>> that
>>> string).
>> The manual pages for these macros are pretty extensive; they are not
>> discussed in the manual.
>>> My first question is, how does MatPreallocateInitialize allocate dnz
>>> and onz? It says we should not malloc or free them, but it takes
>>> PetscInt *dnz not PetscInt **dnz? My understanding of how these
>>> utilities work is that you do your normal matrix assembly, but use
>>> MatPreallocateSet instead of MatSetValues. Then it just does some
>>> counting and when you're done dnz and onz are correct. Am I
>>> correct?
>> Yes. See src/dm/da/src/utils/fdda.c for many examples of its use.
>> Barry
>>> Thanks,
>>> -Andrew
>>> On Wed, Jul 2, 2008 at 1:52 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>> MatGetOwnershipRangeColumn() will give you the needed
>>>> information. If you
>>>> are coding from C/C++
>>>> you might consider using the macro MatPreallocateInitialize() and
>>>> friends. These utilities make it
>>>> somewhat easier, in some circumstances, to count the entries in the
>>>> diagonal and off-diagonal blocks.
>>>> Barry
>>>> On Jul 2, 2008, at 11:58 AM, Andrew Colombi wrote:
>>>>> Hmm... this has not been my experience. When A is not square I'm
>>>>> finding the that the diagonal portion is also not square.
>>>>> Instead it
>>>>> assigns columns to the diagonal portion by evenly distributing
>>>>> the columns
>>>>> among processors. For example, a 4 by 8 would look like:
>>>>> (please excuse the embedded HTML, I need it to specify a fixed-
>>>>> width
>>>>> font)
>>>>> c0 c1 c2 c3 c4 c5 c6 c7
>>>>> p0 r0 X X X X
>>>>> p0 r1 X X X X
>>>>> p1 r2 X X X X
>>>>> p1 r3 X X X X
>>>>> X marks the diagonal portions for each processor. I have
>>>>> attempted to
>>>>> verify this using the program below. If you run this code it
>>>>> will complain
>>>>> that processor 1 must allocate new memory for "(0, 3)" (which I am
>>>>> interpreting to mean the local (0, 3), otherwise known as (2,
>>>>> 3)). Further
>>>>> more you can stop the complaint by incrementing the off-diagonal
>>>>> preallocation, and decrementing the diagonal preallocation.
>>>>> Note, that
>>>>> specifying 0 is some special value that isn't 0. If you specify
>>>>> 0 you won't
>>>>> get any malloc errors.
>>>>> Mat A;
>>>>> int rows = 4;
>>>>> int cols = 8;
>>>>> if (mpi_rank() == 0)
>>>>> MatCreateMPIAIJ(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
>>>>> rows,
>>>>> cols,
>>>>> 2, PETSC_NULL, 1, PETSC_NULL, &A);
>>>>> MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR);
>>>>> static const int R = 2;
>>>>> int set_rows[R] = {0, 1};
>>>>> static const int C = 2;
>>>>> int set_cols[C] = {0, 1};
>>>>> double vals[C*R] = {1., 1., 1., 1.};
>>>>> MatSetValues(A, R, set_rows, C, set_cols, vals, ADD_VALUES);
>>>>> else
>>>>> MatCreateMPIAIJ(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,rows,
>>>>> cols,
>>>>> int set_rows[R] = {2,3};
>>>>> int set_cols[C] = {2,3};
>>>>> MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
>>>>> MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
>>>>> On Wed, Jul 2, 2008 at 6:35 AM, Matthew Knepley
>>>>> <knepley at gmail.com>
>>>>> wrote:
>>>>>> By definition, the diagonal portion is square. Thus you
>>>>>> retrieve the
>>>>>> local rows [start, end), and then the diagonal block is
>>>>>> [start, end) x [start, end)
>>>>>> which you can do with
>>>>>> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatGetOwnershipRange.html
>>>>>> Matt
>>>>>> On Wed, Jul 2, 2008 at 2:52 AM, Andrew Colombi <acolombi at gmail.com
>>>>>> wrote:
>>>>>>> I'm letting PETSC_DECIDE how to distribute the rows and
>>>>>>> columns of my
>>>>>>> non-square matrix, and I want to retrieve the columns it's
>>>>>>> decided to
>>>>>>> make the "Diagonal" for a particular process. How can I do
>>>>>>> that? I'm
>>>>>>> probably missing something obvious here, but I checked the docs.
>>>>>>> In case some context helps (or inspires a work-around):
>>>>>>> I want this information to count the number of d_nnz and o_nnz
>>>>>>> to
>>>>>>> preallocate perfectly. This shouldn't be hard to do, but I
>>>>>>> need to
>>>>>>> know the boundary between off-diagonal and diagonal to do it.
>>>>>>> Thanks,
>>>>>>> -Andrew
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to
>>>>>> which
>>>>>> their experiments lead.
>>>>>> -- Norbert Wiener
