"Diagonal" Columns of MPIAIJ Matrix?
Andrew Colombi acolombi at gmail.com
Wed Jul 2 11:58:42 CDT 2008
Hmm... this has not been my experience.  When A is not square I'm finding
the that the diagonal portion is also not square.  Instead it assigns
columns to the diagonal portion by evenly distributing the columns among
processors.  For example, a 4 by 8 would look like:
(please excuse the embedded HTML, I need it to specify a fixed-width font)
      c0  c1  c2  c3  c4  c5  c6  c7
p0 r0  X   X   X   X
p0 r1  X   X   X   X
p1 r2                  X   X   X   X
p1 r3                  X   X   X   X
X marks the diagonal portions for each processor.  I have attempted to
verify this using the program below.  If you run this code it will complain
that processor 1 must allocate new memory for "(0, 3)" (which I am
interpreting to mean the local (0, 3), otherwise known as (2, 3)).  Further
more you can stop the complaint by incrementing the off-diagonal
preallocation, and decrementing the diagonal preallocation.  Note, that
specifying 0 is some special value that isn't 0. If you specify 0 you won't
get any malloc errors.
Mat A;
int rows = 4;
int cols = 8;
if (mpi_rank() == 0)
    MatCreateMPIAIJ(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, rows,
cols,
                    2, PETSC_NULL, 1, PETSC_NULL, &A);
    MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR);
    static const int R = 2;
    int set_rows[R] = {0, 1};
    static const int C = 2;
    int set_cols[C] = {0, 1};
    double vals[C*R] = {1., 1., 1., 1.};
    MatSetValues(A, R, set_rows, C, set_cols, vals, ADD_VALUES);
else
    MatCreateMPIAIJ(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,rows, cols,
    int set_rows[R] = {2,3};
    int set_cols[C] = {2,3};
MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
On Wed, Jul 2, 2008 at 6:35 AM, Matthew Knepley <knepley at gmail.com> wrote:
> By definition, the diagonal portion is square. Thus you retrieve the
> local rows [start, end), and then the diagonal block is
>  [start, end) x [start, end)
> which you can do with
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatGetOwnershipRange.html
>   Matt
> On Wed, Jul 2, 2008 at 2:52 AM, Andrew Colombi <acolombi at gmail.com> wrote:
>> I'm letting PETSC_DECIDE how to distribute the rows and columns of my
>> non-square matrix, and I want to retrieve the columns it's decided to
>> make the "Diagonal" for a particular process.  How can I do that?  I'm
>> probably missing something obvious here, but I checked the docs.
>> In case some context helps (or inspires a work-around):
>> I want this information to count the number of d_nnz and o_nnz to
>> preallocate perfectly.  This shouldn't be hard to do, but I need to
>> know the boundary between off-diagonal and diagonal to do it.
>> Thanks,
>> -Andrew
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080702/e4aed646/attachment.htm>
