how to get all the singular values of the matrix?
Mon Jan 14 11:32:07 CST 2008
   You cannot compute all the eigenvalues for a large sparse matrix
with PETSc alone.
    Barry
On Jan 14, 2008, at 11:24 AM, Yujie wrote:
> Dear Matt and Hong:
> Based what you said, it looks like a little difficult to evalute the
> matrix in PETSc, especailly regarding a big dimension. However, when
> I select iterative methods, how to select a suitable one based on
> some evaluation? Could you give me some advice? thanks a lot.
> Regards,
> Yujie
> On 1/14/08, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> If you want few selected eigen solutions of sparse matrix,
> you should use sparse eigen solver. Take a look at'
> slepc (http://www.grycap.upv.es/slepc/)
> or use slepc interface with arpack.
> Hong
> On Mon, 14 Jan 2008, Yujie wrote:
> > Thank you for your advice.
> > I have used -ksp_compute_eigenvalues_explicitly to get the eigen
> values.
> > However, it is very very
> > slow because the dimension of the matrix is about ten thousand.
> > Yujie
> > On 1/14/08, Matthew Knepley <knepley at gmail.com> wrote:
> >> You can use
> >> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPComputeEigenvaluesExplicitly.html
> >> with and without a preconditioner. We have not coded the SVD
> >> counterpart, but you can use
> >> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPComputeExplicitOperator.html
> >> and then call the LAPACK yourself.
> >>   Matt
> >> On Jan 13, 2008 11:23 PM, Yujie <recrusader at gmail.com> wrote:
> >>> Hi, everyone
> >>> I want to select iterative methods by observing the singular
> values
> >>> decompostion of the matrix. However, I don't know how to get all
> the
> >>> singular values of the matrix in PETSc. I know the command
> >>> "-ksp_monitor_singular_value" may get the max and min singular
> values at
> >>> each iteration. How to get the singular values of the matrix I
> want to
> >>> solve? In addition, when I use the preconditioned iterative
> method, how
> >> to
> >>> get the singular values of the preconditioned iterative operator?
> >>> thanks a lot.
> >>> Regards,
> >>> Yujie
> >> What most experimenters take for granted before they begin their
> >> experiments is infinitely more interesting than any results to
> which
> >> their experiments lead.
> >> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080114/040e69e6/attachment.htm>
