how to add a parallel MatMatSolve() function?
Yujie
recrusader at gmail.com
Fri Feb 29 21:35:46 CST 2008
Dear Barry:
I have checked SuperLU_Dist codes. It looks like relative easy to write
codes for AX=B based on MatSolve(). This is why I ask you the above problem.
how about your advice?
thanks a lot.
Yujie
On 3/1/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Some direct solver packages have support for solving directly with
> several right hand sides at the same time.They could be a bit faster than
> solving one at a time; maybe 30% faster at most, not 10 times faster. What
> is more
> important solving the problem you want to solve in a reasonable time or
> solving the problem a bit faster
> after spending several weeks writing the much more complicated code?
> Barry
> On Feb 29, 2008, at 8:01 PM, Yujie wrote:
> Dear Barry:
> Thank you for your help. I check the codes
> roughly, the method in the codes is to use MatSolve() to solve AX=B in a loop. I also consider such a method.
> However, I am wondering whether it is slower than the method that directly
> solves AX=B? thanks again.
> Regards,
> Yujie
> On 2/29/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Please edit the file src/mat/interface/matrix.c and remove the
> > function MatMatSolve(). Replace it with the following two functions,
> > then run "make lib shared" in that directory. Please let us know at
> > petsc-maint at mcs.anl.gov
> > if it crashes or produces incorrect
> > results.
> > Barry
> > #undef __FUNCT__
> > #define __FUNCT__ "MatMatSolve_Basic"
> > PetscErrorCode PETSCMAT_DLLEXPORT MatMatSolve_Basic(Mat A,Mat B,Mat X)
> > PetscErrorCode ierr;
> > Vec b,x;
> > PetscInt m,N,i;
> > PetscScalar *bb,*xx;
> > PetscFunctionBegin;
> > ierr = MatGetArray(B,&bb);CHKERRQ(ierr);
> > ierr = MatGetArray(X,&xx);CHKERRQ(ierr);
> > ierr = MatGetLocalSize(B,&m,PETSC_NULL);CHKERRQ(ierr); /* number
> > local rows */
> > ierr = MatGetSize(B,PETSC_NULL,&N);CHKERRQ(ierr); /* total
> > columns in dense matrix */
> > ierr = VecCreateMPIWithArray(A-
> > >hdr.comm,m,PETSC_DETERMINE,PETSC_NULL,&b);CHKERRQ(ierr);
> > >hdr.comm,m,PETSC_DETERMINE,PETSC_NULL,&x);CHKERRQ(ierr);
> > for (i=0; i<N; i++) {
> > ierr = VecPlaceArray(b,bb + i*m);CHKERRQ(ierr);
> > ierr = VecPlaceArray(x,xx + i*m);CHKERRQ(ierr);
> > ierr = MatSolve(A,b,x);CHKERRQ(ierr);
> > ierr = VecDestroy(b);CHKERRQ(ierr);
> > ierr = VecDestroy(x);CHKERRQ(ierr);
> > PetscFunctionReturn(0);
> > #undef __FUNCT__
> > #define __FUNCT__ "MatMatSolve"
> > MatMatSolve - Solves A X = B, given a factored matrix.
> > Collective on Mat
> > Input Parameters:
> > + mat - the factored matrix
> > - B - the right-hand-side matrix (dense matrix)
> > Output Parameter:
> > . B - the result matrix (dense matrix)
> > Notes:
> > The matrices b and x cannot be the same. I.e., one cannot
> > call MatMatSolve(A,x,x).
> > Notes:
> > Most users should usually employ the simplified KSP interface for
> > linear solvers
> > instead of working directly with matrix algebra routines such as
> > this.
> > See, e.g., KSPCreate(). However KSP can only solve for one vector
> > (column of X)
> > at a time.
> > Level: developer
> > Concepts: matrices^triangular solves
> > .seealso: MatMatSolveAdd(), MatMatSolveTranspose(),
> > MatMatSolveTransposeAdd(), MatLUFactor(), MatCholeskyFactor()
> > PetscErrorCode PETSCMAT_DLLEXPORT MatMatSolve(Mat A,Mat B,Mat X)
> > PetscFunctionBegin;
> > PetscValidHeaderSpecific(A,MAT_COOKIE,1);
> > PetscValidType(A,1);
> > PetscValidHeaderSpecific(B,MAT_COOKIE,2);
> > PetscValidHeaderSpecific(X,MAT_COOKIE,3);
> > PetscCheckSameComm(A,1,B,2);
> > PetscCheckSameComm(A,1,X,3);
> > if (X == B) SETERRQ(PETSC_ERR_ARG_IDN,"X and B must be different
> > matrices");
> > if (!A->factor) SETERRQ(PETSC_ERR_ARG_WRONGSTATE,"Unfactored
> > matrix");
> > if (A->cmap.N != X->rmap.N) SETERRQ2(PETSC_ERR_ARG_SIZ,"Mat A,Mat
> > X: global dim %D %D",A->cmap.N,X->rmap.N);
> > if (A->rmap.N != B->rmap.N) SETERRQ2(PETSC_ERR_ARG_SIZ,"Mat A,Mat
> > B: global dim %D %D",A->rmap.N,B->rmap.N);
> > if (A->rmap.n != B->rmap.n) SETERRQ2(PETSC_ERR_ARG_SIZ,"Mat A,Mat
> > B: local dim %D %D",A->rmap.n,B->rmap.n);
> > if (!A->rmap.N && !A->cmap.N) PetscFunctionReturn(0);
> > ierr = MatPreallocated(A);CHKERRQ(ierr);
> > ierr = PetscLogEventBegin(MAT_MatSolve,A,B,X,0);CHKERRQ(ierr);
> > if (!A->ops->matsolve) {
> > ierr = PetscInfo1(A,"Mat type %s using basic MatMatSolve",
> > ((PetscObject)A)->type_name);CHKERRQ(ierr);
> > ierr = MatMatSolve_Basic(A,B,X);CHKERRQ(ierr);
> > } else {
> > ierr = (*A->ops->matsolve)(A,B,X);CHKERRQ(ierr);
> > ierr = PetscLogEventEnd(MAT_MatSolve,A,B,X,0);CHKERRQ(ierr);
> > ierr = PetscObjectStateIncrease((PetscObject)X);CHKERRQ(ierr);
> > On Feb 29, 2008, at 6:46 PM, Yujie wrote:
> > > Hi, everyone
> > > I am considering to add a parallel MatMatSolve() into PETSc based on
> > > SuperLu_DIST or Spooles. If I want to use it like current sequential
> > > MatMatSolve() in the application codes, how to do it? Could you give
> > > me some examples about how to add a new function?
> > > thanks a lot.
> > > Regards,
> > > Yujie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080301/be30bb20/attachment.htm>
