PetscFOpen with mode "a+"
Barry Smith
bsmith at mcs.anl.gov
Wed Dec 31 16:32:17 CST 2008
Here is the relevant code
PetscErrorCode PETSC_DLLEXPORT PetscFOpen(MPI_Comm comm,const char
name[],const char mode[],FILE **fp)
PetscErrorCode ierr;
PetscMPIInt rank;
FILE *fd;
char fname[PETSC_MAX_PATH_LEN],tname[PETSC_MAX_PATH_LEN];
PetscFunctionBegin;
ierr = MPI_Comm_rank(comm,&rank);CHKERRQ(ierr);
if (!rank) {
PetscTruth isstdout,isstderr;
ierr = PetscStrcmp(name,"stdout",&isstdout);CHKERRQ(ierr);
ierr = PetscStrcmp(name,"stderr",&isstderr);CHKERRQ(ierr);
if (isstdout || !name) {
fd = PETSC_STDOUT;
} else if (isstderr) {
fd = PETSC_STDERR;
} else {
ierr =
PetscStrreplace
(PETSC_COMM_SELF,name,tname,PETSC_MAX_PATH_LEN);CHKERRQ(ierr);
ierr = PetscFixFilename(tname,fname);CHKERRQ(ierr);
ierr = PetscInfo1(0,"Opening file %s\n",fname);CHKERRQ(ierr);
fd = fopen(fname,mode);
if (!fd) SETERRQ1(PETSC_ERR_FILE_OPEN,"Unable to open file %s
\n",fname);
It appears the mode that you pass in is passed into fopen()
unchanged; thus if you pass in an 'a' or 'a+' that should
be passed into fopen() you can confirm this in the debugger. Start up
your program (with one process) with the
option -start_in_debugger once it is in the debugger do "break fopen"
then "cont" (without the quotes). When it gets to the
relevant fopen() check the value of mode. Use the debug version of
PETSc (that is do not config/configure.py with the
option --with-debugging=0)
Please report back to petsc-maint at mcs.anl.gov
Barry
On Dec 31, 2008, at 2:30 PM, (Rebecca) Xuefei YUAN wrote:
> I tried PetscViewerFileSetMode and use the "FILE_MODE_APPEND", but
> it seems that the file has been overwritten,too.
> I was not able to find any examples in tutorials, is there one using
> it?
> Thanks a lot!
> Quoting Matthew Knepley <knepley at gmail.com>:
>> You use a ViewerCreate() and then
>> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Viewer/PetscViewerFileSetMode.html
>> to set append, and then FileSetName() to open the file.
>> Matt
>> On Wed, Dec 31, 2008 at 10:24 AM, (Rebecca) Xuefei YUAN <xy2102 at columbia.edu
>>> wrote:
>>> Hi,All,
>>> I tried to use PetscFOpen to write the numerical result to a file,
>>> and I
>>> would like to use the mode "a+" to add my result to the existing
>>> content in
>>> my file. However, whenever the new result comes out, it will
>>> overwrite the
>>> existing content in the file. Is there any problem here?
>>> Thanks a lot!
>>> Rebecca
>> experiments
>> is infinitely more interesting than any results to which their
>> experiments
>> lead.
>> -- Norbert Wiener
> Department of Applied Physics and Applied Mathematics
> Columbia University
> Tel:917-399-8032
> www.columbia.edu/~xy2102
