get several submatrices from several matrices and combine submatrices into another matrix
Yujie recrusader at gmail.com
Wed Dec 31 12:24:36 CST 2008
On Wed, Dec 31, 2008 at 9:29 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Yes.
>    Matt
> On Wed, Dec 31, 2008 at 11:25 AM, Yujie <recrusader at gmail.com> wrote:
>> Dear Matthew:
>> thank you very much. Regarding my problem about MatAXPY() for MPIDense, I
>> have checked SEQDense has this function. To my knowledge, in each node,
>> MPIDense's format is SEQDense, right? if it is, I should ba able to write a
>> MPIDense-based function using SEQDense? thanks  a lot.
>> Regards,
>> Yujie
>> On Wed, Dec 31, 2008 at 8:56 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>> Yes, you can have 0 length IS arguments.
>>>   Matt
>>> On Wed, Dec 31, 2008 at 10:21 AM, Yujie <recrusader at gmail.com> wrote:
>>>> Hi, PETSc Developers
>>>> In parallel mode, I have 3 MPIDense matrices, A1, A2, A3. Now, I need to
>>>> exact submatrices B1, B2, B3 in parallel mode from A1, A2, A3 respectively.
>>>> I know I should use MatGetSubMatrix(). My problem is in
>>>> MatGetSubMatrix(Mat mat,IS isrow,IS iscol,PetscInt csize,MatReuse cll,Mat *newmat)
>>>> , the parameter "isrow" means "rows this processor should obtain". if Bi
>>>> in some nodes (cpus) of the cluster (Ai have rows in them) don't have rows,
>>>> is it work?
>>>> After getting Bi, I will create MPIDense-based C and combine them into C
>>>> like
>>>>      B1
>>>> C= B2
>>>>      B3
>>>> MatGetRow();
>>>> MatSetValues() should work, right?
>>>> Could you give me some comments about these operations? thanks a lot.
>>>> Happy new year!
>>>> Regards,
>>>> Yujie
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081231/f0cbac00/attachment.htm>
