get several submatrices from several matrices and combine submatrices into another matrix
Yujie
recrusader at gmail.com
Wed Dec 31 11:25:26 CST 2008
Dear Matthew:
thank you very much. Regarding my problem about MatAXPY() for MPIDense, I
have checked SEQDense has this function. To my knowledge, in each node,
MPIDense's format is SEQDense, right? if it is, I should ba able to write a
MPIDense-based function using SEQDense? thanks a lot.
Yujie
On Wed, Dec 31, 2008 at 8:56 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Yes, you can have 0 length IS arguments.
> Matt
> On Wed, Dec 31, 2008 at 10:21 AM, Yujie <recrusader at gmail.com> wrote:
>> Hi, PETSc Developers
>> In parallel mode, I have 3 MPIDense matrices, A1, A2, A3. Now, I need to
>> exact submatrices B1, B2, B3 in parallel mode from A1, A2, A3 respectively.
>> I know I should use MatGetSubMatrix(). My problem is in
>> MatGetSubMatrix(Mat mat,IS isrow,IS iscol,PetscInt csize,MatReuse cll,Mat *newmat)
>> , the parameter "isrow" means "rows this processor should obtain". if Bi
>> in some nodes (cpus) of the cluster (Ai have rows in them) don't have rows,
>> is it work?
>> After getting Bi, I will create MPIDense-based C and combine them into C
>> like
>> B1
>> C= B2
>> B3
>> MatGetRow();
>> MatSetValues() should work, right?
>> Could you give me some comments about these operations? thanks a lot.
>> Happy new year!
>> Regards,
>> Yujie
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081231/3d7e9f28/attachment.htm>
