PetscFOpen with mode "a+"
Matthew Knepley
knepley at gmail.com
Wed Dec 31 10:54:32 CST 2008
You use a ViewerCreate() and then
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Viewer/PetscViewerFileSetMode.html
to set append, and then FileSetName() to open the file.
Matt
On Wed, Dec 31, 2008 at 10:24 AM, (Rebecca) Xuefei YUAN <xy2102 at columbia.edu
> wrote:
> Hi,All,
> I tried to use PetscFOpen to write the numerical result to a file, and I
> would like to use the mode "a+" to add my result to the existing content in
> my file. However, whenever the new result comes out, it will overwrite the
> existing content in the file. Is there any problem here?
> Thanks a lot!
> Rebecca
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081231/a9a6bae9/attachment.htm>
