Problem installing petsc on a Blue Gene/L
Wed Dec 31 01:08:45 CST 2008
On Tue, 30 Dec 2008, Shi Jin wrote:
> > However it is likely the attached patch will fix this
> > problem [it is
> > scheduled for the next patch update]
> > cd config/BuildSystem
> > patch -Np1 < mpi-check-cray.patch
> > Satish
> Thank you very much. Actually I just used the petsc-dev code and it worked without any problem.  Thank you very much for your help.
Ok - that above patch is in current petsc-dev - so it must have fixed the problem.
> By the way, could you please suggest a petsc test case of KSP solver on the Blue Gene? There are many tests coming with PETSc. It would be great if I could just focus on one test.
Perhaps you can check src/ksp/ksp/examples/tutorials/ex2.c
Satish
> Thanks again.
> Shi
