exact MPI-based matrix using MatGetSubMatrix()
Wed Dec 24 13:15:44 CST 2008
   If you want the resulting A11, etc to have the same distribution as
B then when you construct A you will
have to construct it with the rows/columns from the 1 block interlaced
with the 2 block.  This means
you would form A it would look
a00 a0,n a0,1 a0,n+1 ...
an,0 an,n an,1 an,n+1 ..
a1,0 a1,n ...
  Barry
On Dec 23, 2008, at 7:49 PM, Yujie wrote:
> Hi, PETSc Developer
> Now, I have two matrices, A and B. A (its dimension is 2N*2N) is
> MPIDense format. B (N*N) is MPIAIJ.
> I want to exact four matrices from A, like this
>      A11 A12
> A=
>      A21 A22
> each submatrices is multplied by B. My question is if A11, A12, A21,
> A22 have same distribution with B, how to do it with
> MatGetSubMatrix()?
> Thanks a lot.
> Regards,
> Yujie
