about MatSetValue() and VecSetValue()
Fri Dec 19 17:32:48 CST 2008
    If INSERT_VALUE is being used then ONE of the values you put in
ends up being the value; which one is
not under your control. If ADD_VALUES is used then the sum of all the
values is used.
On Dec 19, 2008, at 5:28 PM, Yujie wrote:
> Hi, PETSc developer
> I am wondering if several cpus simultaneously insert the values in
> the same position using MatSetValue() or VecSetValue(), how do the
> functions deal with it? thanks a lot.
> Regards,
> Yujie
