Weird (?) results obtained from experiments with the SNESMF module
Lisandro Dalcin dalcinl at gmail.com
Fri Dec 19 14:10:18 CST 2008
Then the problem is restarted GMRES, the default restart of 30 is not
enough....
But before you go on trying... do this... Add:
-ksp_type cg
and let me know your results ;-)
On Fri, Dec 19, 2008 at 5:54 PM, Rafael Santos Coelho
<rafaelsantoscoelho at gmail.com> wrote:
> Hi, Lisandro,
>> Did you make sure to pass '-pc_type none' for both JFNK and NK??
> Yes, I did.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
