HYPRE_BoomerAMG and FEI interface
Anirban Chatterjee achatter at cse.psu.edu
Fri Dec 12 13:43:31 CST 2008
Does the data have to be in a special format? Because I want to use
Hypre's Finite Element Interface to input unstructured meshes.
Basically, if I format the data in the Hypre FEI format and send it
through Petsc with these command line options then will it work.
Anirban
Matthew Knepley wrote:
> -pc_type hypre -pc_hypre_type boomeramg
>   Matt
> On Fri, Dec 12, 2008 at 11:10 AM, Anirban Chatterjee
> <achatter at cse.psu.edu <mailto:achatter at cse.psu.edu>> wrote:
>     Hi,
>     I want to use hypre from petsc. Specifically, how do I use the
>     BoomerAMG solver in hypre with the Finite Element Interface (FEI)
>     through petsc?
>     I have installed petsc along with the hypre package as an external
>     package.
>     Thanks,
>     Anirban
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
