BlockSolve95 error
Panyasantisuk Jarunan
Jarunan.Panyasantisuk at eleves.ec-nantes.fr
Fri Dec 12 09:46:02 CST 2008
it still does not work in a big case, as you adviced. I will try to
investigate.
Jarunan
Jarunan PANYASANTISUK
MSc. in Computational Mechanics
Erasmus Mundus Master Program
Ecole Centrale de Nantes
1, rue de la noë, 44321 NANTES, FRANCE
Keita Teranishi <keita at cray.com> a écrit :
> Jarunan,
> Make the value for MAX_NUM_MSGS bigger in BlockSolve95/include/BSprivate.h.
>> #define MAX_NUM_MSGS 10000000
> You will need to change the values of other "MAX_XXXX" variables in
> the header files because computers nowadays have much bigger
> capacity/capability than those in mid 90's.
> Keita Teranishi
> Math Software Group
> Cray, Inc.
> keita at cray.com
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Barry Smith
> Sent: Wednesday, November 26, 2008 3:20 PM
> To: petsc-users at mcs.anl.gov
> Subject: Re: BlockSolve95 error
> I have no idea. BlockSolve has not been supported by its
> developers for like
> 10 years. Those messages are coming from inside BlockSolve which we
> don't
> support.
> I'm sorry for the terse response but we cannot support all the
> orphaned parallel
> numerical software in the world.
> Barry
> On Nov 26, 2008, at 8:43 AM, Panyasantisuk Jarunan wrote:
>> Hello,
>> Could you please explain the error I got from running code with
>> blocksolve95?:
>> ERROR: Code -30 occured at Line 103 in File BMcomp_msg.c: Too many
>> messages in comp_msg
>> ERROR: Code -30 occured at Line 48 in File BSsetup_factor.c
>> I cannot find BMcomp_msg.c and BSsetup_factor.c anywhere.
>> For running I use: mpirun -np 3 -machinefile machines ./test2
>> It works with other test cases though.
>> In the fortran code:
>> call MatCreate(PETSC_COMM_WORLD,D,ierr)
>> call MatSetSizes(D,N,N,PETSC_DETERMINE,PETSC_DETERMINE,
>> $ ierr)
>> call MatSetType(D,MATMPIROWBS,ierr)
>> call MatSetFromOptions(D,ierr)
>> call MatMPIRowbsSetPreallocation(D,nz,PETSC_NULL_INTEGER,ierr)
>> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>> call KSPSetOperators(ksp,D,D,DIFFERENT_NONZERO_PATTERN,ierr)
>> call KSPGetPC(ksp,pc,ierr)
>> call PCSetType(pc,PCILU,ierr)
>> Thank you before hand
>> Regards,
>> Jarunan
