Double solve on the coarse level?
ntardieu at giref.ulaval.ca
Mon Dec 8 12:59:45 CST 2008
Dear PETSc users,
We designed a multigrid solver based on the PCMG framework.
But when one looks at the output, it seems that the system on the coarsest
level is solved twice : indeed the same residuals appear twice. Is it a
consequence of using a W cycle with an iteratif solver on the coarsest
level?
The PC object and a typical output are given below.
Nicolas
PC Object:
type: mg
MG: type is MULTIPLICATIVE, levels=2 cycles=w, pre-smooths=1,
post-smooths=1
Coarse gride solver -- level 0 -------------------------------
KSP Object:(mg_coarse_)
type: cr
maximum iterations=30, initial guess is zero
tolerances: relative=1e-06, absolute=1e-50, divergence=10000
left preconditioning
PC Object:(mg_coarse_)
type: sor
SOR: type = local_symmetric, iterations = 1, omega = 1
linear system matrix = precond matrix:
Matrix Object:
type=seqaij, rows=24497, cols=24497
total: nonzeros=936401, allocated nonzeros=0
not using I-node routines
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object:(mg_levels_1_)
type: chebychev
Chebychev: eigenvalue estimates: min = 0.01, max = 100
maximum iterations=3, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
PC Object:(mg_levels_1_)
type: sor
Matrix Object:
type=seqaij, rows=59833, cols=59833
total: nonzeros=670149, allocated nonzeros=670149
Up solver (post-smoother) on level 1 -------------------------------
type: chebychev
type: sor
Matrix Object:
Matrix Object:
Typical output :
0 KSP Residual norm 8.529532792227e-01
1 KSP Residual norm 8.312168822014e-01
2 KSP Residual norm 7.962289819435e-01
3 KSP Residual norm 7.498665547818e-01
0 KSP Residual norm 8.623070846983e-01 <<<<<<<<<<
1 KSP Residual norm 4.994728639387e-01
2 KSP Residual norm 4.441045285060e-01
3 KSP Residual norm 4.036899174922e-01
4 KSP Residual norm 3.741251351308e-01
5 KSP Residual norm 3.449669992123e-01
6 KSP Residual norm 3.220670285389e-01
7 KSP Residual norm 2.974753633724e-01
8 KSP Residual norm 2.786493949211e-01
9 KSP Residual norm 2.666365822398e-01
10 KSP Residual norm 2.615313007214e-01
11 KSP Residual norm 2.580757152907e-01
12 KSP Residual norm 2.549505151556e-01
13 KSP Residual norm 2.509670840632e-01
14 KSP Residual norm 2.464315316006e-01
15 KSP Residual norm 2.416198261586e-01
16 KSP Residual norm 2.359854861997e-01
17 KSP Residual norm 2.298769116813e-01
18 KSP Residual norm 2.232203276735e-01
19 KSP Residual norm 2.153461917946e-01
20 KSP Residual norm 2.072492142809e-01
21 KSP Residual norm 1.983342705665e-01
22 KSP Residual norm 1.894778760982e-01
23 KSP Residual norm 1.803772952130e-01
24 KSP Residual norm 1.718394016178e-01
25 KSP Residual norm 1.639952865611e-01
26 KSP Residual norm 1.571843225056e-01
27 KSP Residual norm 1.512651261054e-01
28 KSP Residual norm 1.459688114323e-01
29 KSP Residual norm 1.410245577886e-01
30 KSP Residual norm 1.364936912778e-01
0 KSP Residual norm 2.864424649239e+00
1 KSP Residual norm 2.719941822422e+00
2 KSP Residual norm 2.486679927440e+00
3 KSP Residual norm 2.176182306332e+00
0 KSP preconditioned resid norm 3.133018965496e+02 true resid norm
5.229629619561e+01 ||Ae||/||Ax|| 1.000000000000e+00
