DMMG solver convergence with single precision?
Barry Smith
bsmith at mcs.anl.gov
Tue Dec 2 22:43:46 CST 2008
I have reproduced this. I expect that you would not be able to
decrease the residual by more than a factor
of 10^6 but the results below are worse than I expected.
After first running it I thought I would have to say "I have no
idea". But then I ran
barry-smiths-macbook-pro-17:ksp/examples/tutorials] bsmith% ./ex34 -
ksp_monitor_true_residual -dmmg_nlevels 6 -ksp_type fgmres -
ksp_gmres_restart 4
0 KSP preconditioned resid norm 4.451733827591e-02 true resid
norm 4.451733827591e-02 ||Ae||/||Ax|| 1.000000000000e+00
1 KSP preconditioned resid norm 2.803983807098e-04 true resid
norm 2.803510287777e-04 ||Ae||/||Ax|| 6.297569256276e-03
2 KSP preconditioned resid norm 7.431745416397e-06 true resid
norm 7.503178949264e-06 ||Ae||/||Ax|| 1.685450988589e-04
3 KSP preconditioned resid norm 4.979479399481e-06 true resid
norm 6.953502179385e-06 ||Ae||/||Ax|| 1.561976241646e-04
4 KSP preconditioned resid norm 6.971503353270e-06 true resid
norm 6.971503353270e-06 ||Ae||/||Ax|| 1.566019782331e-04
5 KSP preconditioned resid norm 4.069146442021e-08 true resid
norm 8.315442414641e-07 ||Ae||/||Ax|| 1.867910941655e-05
Residual norm 8.31544e-07
Error norm 0.000372035
Error norm 9.54604e-05
Error norm 1.38928e-07
Part of the problem is coming from the gmres not generating a good
orthonormal basis of directions, so I ran
[barry-smiths-macbook-pro-17:ksp/examples/tutorials] bsmith% ./ex34 -
ksp_gmres_modifiedgramschmidt
1 KSP preconditioned resid norm 2.803631359711e-04 true resid
norm 2.803224197123e-04 ||Ae||/||Ax|| 6.296926643699e-03
2 KSP preconditioned resid norm 6.318659416138e-06 true resid
norm 6.395913715096e-06 ||Ae||/||Ax|| 1.436724269297e-04
3 KSP preconditioned resid norm 5.441804660222e-06 true resid
norm 5.559954843193e-06 ||Ae||/||Ax|| 1.248941407539e-04
4 KSP preconditioned resid norm 5.441734174383e-06 true resid
norm 5.580118795478e-06 ||Ae||/||Ax|| 1.253470836673e-04
5 KSP preconditioned resid norm 4.763217020809e-06 true resid
norm 4.965124844603e-06 ||Ae||/||Ax|| 1.115323830163e-04
6 KSP preconditioned resid norm 1.149661784439e-06 true resid
norm 1.742098334034e-06 ||Ae||/||Ax|| 3.913302862202e-05
7 KSP preconditioned resid norm 1.129046836468e-06 true resid
norm 1.607488229638e-06 ||Ae||/||Ax|| 3.610926069086e-05
8 KSP preconditioned resid norm 1.129005681832e-06 true resid
norm 1.682757897470e-06 ||Ae||/||Ax|| 3.780005499721e-05
9 KSP preconditioned resid norm 9.863339300864e-07 true resid
norm 1.657332745708e-06 ||Ae||/||Ax|| 3.722892870428e-05
10 KSP preconditioned resid norm 3.080494650476e-07 true resid
norm 1.298029587815e-06 ||Ae||/||Ax|| 2.915784352808e-05
Residual norm 1.29803e-06
Error norm 0.00100342
Error norm 0.000631685
Error norm 6.85996e-07
It looks like using the modified gram-schmidt orthogonalization helps
(that is it takes less iterations than with the classical (default) BUT
looking more closely we see that it actually terminated too early and
the answer is crappy.
So lets turn off ALL the GMRES stuff
ksp_monitor_true_residual -dmmg_nlevels 6 -ksp_type richardson -
mg_levels_ksp_type richardson
0 KSP preconditioned resid norm 3.698072814941e+02 true resid
1 KSP preconditioned resid norm 4.145919799805e+01 true resid
norm 9.632258675992e-03 ||Ae||/||Ax|| 2.163709551096e-01
2 KSP preconditioned resid norm 4.848244190216e+00 true resid
norm 1.894293935038e-03 ||Ae||/||Ax|| 4.255182296038e-02
3 KSP preconditioned resid norm 5.902504324913e-01 true resid
norm 3.106203221250e-04 ||Ae||/||Ax|| 6.977513432503e-03
4 KSP preconditioned resid norm 7.403665781021e-02 true resid
norm 4.669937698054e-05 ||Ae||/||Ax|| 1.049015438184e-03
5 KSP preconditioned resid norm 9.483236819506e-03 true resid
norm 6.756537914043e-06 ||Ae||/||Ax|| 1.517731725471e-04
6 KSP preconditioned resid norm 1.249413820915e-03 true resid
norm 1.256137807104e-06 ||Ae||/||Ax|| 2.821682210197e-05
Residual norm 1.25614e-06
Error norm 0.000369181
Error norm 9.46438e-05
Error norm 1.37756e-07
The final residual doesn't look that great but if you look at the
error norms you see that the solution has fully converged.
This final run is actually classical multigrid. So it looks like that
is the way to go; BUT you have to be very careful with how
you decide when it has converged. Obviously you want to stop as soon
as the algebraic error is smaller than the truncation error.
But, sadly we don't know what the algebraic error is (we only know the
residual) and we do not know what the truncation error is.
My hack convergence criteria would be to stop as soon as the residual
norm DOES NOT decrease by at least (say) 20%
To do a little better we can use SOR as the smoother instead of ILU
mg_levels_ksp_type richardson -mg_levels_pc_type sor
0 KSP preconditioned resid norm 3.202437744141e+02 true resid
1 KSP preconditioned resid norm 1.194643592834e+01 true resid
norm 2.088646404445e-03 ||Ae||/||Ax|| 4.691759496927e-02
2 KSP preconditioned resid norm 4.755175709724e-01 true resid
norm 1.131777826231e-04 ||Ae||/||Ax|| 2.542330417782e-03
3 KSP preconditioned resid norm 1.988304778934e-02 true resid
norm 6.019943612046e-06 ||Ae||/||Ax|| 1.352269464405e-04
4 KSP preconditioned resid norm 8.689521928318e-04 true resid
norm 8.886481737136e-07 ||Ae||/||Ax|| 1.996184437303e-05
Residual norm 8.88648e-07
Error norm 0.000368883
Error norm 9.4803e-05
Error norm 1.37996e-07
Hope this helps,
Barry
On Dec 2, 2008, at 7:52 PM, Chris Cooper wrote:
> Hi,
> Just wondering if there are any techniques for improving DMMG
> convergence on a linear problem when operating in single precision?
> eg using ksp example 34 in Petsc 2.3.3 with multigrid levels changed
> to 6...
> double precision:
> 0 KSP Residual norm 4.451733404502e-02
> 1 KSP Residual norm 2.801676364873e-04
> 2 KSP Residual norm 3.215426166316e-06
> 3 KSP Residual norm 5.446277176355e-08
> Residual norm 5.44628e-08
> Error norm 0.000356798
> Error norm 9.21724e-05
> Error norm 1.34208e-07
> single precision:
> 0 KSP Residual norm 4.450287297368e-02
> 1 KSP Residual norm 2.799208450597e-04
> 2 KSP Residual norm 2.232483529951e-05
> 3 KSP Residual norm 1.575733222126e-05
> 4 KSP Residual norm 1.286925271415e-05
> 27 KSP Residual norm 4.369261660031e-06
> 28 KSP Residual norm 4.287577212381e-06
> 29 KSP Residual norm 4.210308816255e-06
> 30 KSP Residual norm 2.235170904896e-05
> 31 KSP Residual norm 1.709007477757e-07
> Residual norm 8.45584e-07
> Error norm 0.000370784
> Error norm 9.54664e-05
> Error norm 1.38935e-07
> thanks,
> Chris Cooper
> Animal Logic
> Animal Logic
> http://www.animallogic.com
> Please think of the environment before printing this email.
> This email and any attachments may be confidential and/or
> privileged. If you are not the intended recipient of this email, you
> must not disclose or use the information contained in it. Please
> notify the sender immediately and delete this document if you have
> received it in error. We do not guarantee this email is error or
> virus free.
