compiling PETSc with Intel MKL 10.0.1.14
Paul T. Bauman
pbauman at ices.utexas.edu
Sat Aug 30 09:21:10 CDT 2008
Sorry this took so long to get around to doing. So it turns out that
there's a newer version of 2.3.3p13 posted at the PETSc ftp server. This
worked flawlessly with the new MKL. I guess it got fixed and checked-in,
but not under a new patch?
Paul
Barry Smith wrote:
> Please send the configure.log to petsc-maint at mcs.anl.gov
> Barry
> On Aug 15, 2008, at 1:39 PM, Paul T. Bauman wrote:
>> Was there ever a fix/workaround introduced for this? I'm using
>> 2.3.3p13 and I'm having trouble getting the config to recognize mkl
>> 10.0.3.020.
>> Thanks,
>> Paul
>> Barry Smith wrote:
>>> Could you email to petsc-maint at mcs.anl.gov ALL the messages as to
>>> what goes wrong with
>>> our current linking so we can fix it?
>>> Thanks
>>> Barry
>>> On Jun 18, 2008, at 3:32 PM, Randall Mackie wrote:
>>>> We've upgraded Intel MKL to version 10.0, but in this version,
>>>> Intel has
>>>> changed how libraries are suppose to be linked. For example, the
>>>> libmkl_lapack.a
>>>> is a dummy library, but that's what the PETSc configure script
>>>> looks for.
>>>> The documentation says, for example, to compile LAPACK in the
>>>> static case,
>>>> use libmkl_lapack.a libmkl_em64t.a
>>>> and in the layered pure case to use
>>>> libmkl_intel_lp64.a libmkl_intel_thread.a libmkl_core.a
>>>> However, the PETSC configuration wants -lmkl_lapack -lmkl -lguide
>>>> -lpthread
>>>> Any suggestions are appreciated.
>>>> Randy
